I just got my MG(machine ground) AD-20 a couple days ago. I much prefer the blade with no hole so i got this directly from Demko. The handle is very comfortable and the lock is so fidget friendly. Also no blade play at any direction at all. This knife has potential to be one of the best lock in the market in terms of strength, durability, ease of use & maintenance.
Before anyone ask, no, the Shark lock tab doesn't cause any hotspot at all. I've held the knife in hammer grip, saber grip, Filipino grip, reverse edge-in, reverse edge-out etc. and i can't feel the the lock tab at all, and i don't have a meaty hand. The only thing you change is when holding in saber grip, you put your thumb on the lock tab which is further than where i would usually put my thumb at for this grip. But i almost never cut anything with saber grip and i'd imagine it's more for fighting, if that's the case it actually helps because it extends the tip.
The only thing that i still need to get used to is the balance. Compared to AD10 and AD15, this version of AD20 is quite blade heavy, because the blade is a huge chunk of 3/16" thick 20CV steel and the handle is mostly G-10 with some of liners around the top. The balance point is slightly near the lower half of the pivot screw, so above where your index finger will be, so the knife doesn't feel as lively in hand as compared to the AD15 or AD10 despite being lighter.
The overall length of the AD-20 is about 8.65" and the handle length is about 5.05". It's slightly shorter than the AD-10 and about 1/8" longer than AD-15. The weight for my MG version is 6.35oz. I wished that the knife is shorter overall, maybe take 1/2" off the whole thing and make it around 8-8.25" so more Hinderer XM-18 sized. Also, if they can shave the blade thickness to 4mm it should make the knife much more balance(even though i prefer thicker blade). Luckily Demko mentioned that he has a smaller version with 3" cutting edge in the work.
Overall I like the AD-20 much more than the AD-15. This is a great design that solves all the complains about Triad lock not being fidget friendly. IMO Triad is still my favorite lock because it's the most elegant design without requiring any liners, but the Shark Lock is definitely a close second.
