I recently picked up the full set of Edge Pro diamond matrix stones so I could make my Edge Pro system relevant again when sharpening "super steels". I'm a big sharpening nerd so I'd binge watched and read everything I could find about the stones before using them. I also bought Diemaker's stone dressing set of loose abrasives so I had the proper supplies for dressing them. I use the retractable table magnet, slide guide, angle cube, and drill stop collar.
My issue I'm running into is apparent micro chipping on the apex. I have been able to repair and fix the issue after sharpening a second or third time, but seem to be running into the issue on every "first" sharpening of a knife. My process has been as follows....
1. Reprofile edge with 80 grit stone. Keep pressure light, back and forth strokes until I apex and a burr forms.
2. Switch to edge trailing only on the 80 grit, just a few light sweeping passes each side to minimize the burr.
3. Move through the rest of the grits, light pressure, edge trailing only, slight sweeping left to right motion on the downstroke with the stone. 10-15 strokes per side, minimum.
4. Light stropping with bare leather on Edge Pro.
I've been inspecting the apex through the progression with my inexpensive pocket microscope. It was very cheap, but it actually works surprisingly well, 60x magnification. The apex does clean up some as I move up through the grits. I've tried doubling the amount of strokes per side which helped some, but did not remove all micro chips. I've had this problem on most all of my higher end, hard steels. K390, Maxamet, Rex45, etc. Only way I've been able to fully remove them is to do a complete re-sharpening, starting back on the 80 grit.
I've dressed my stones a couple of times with proper loose abrasives, but that didn't change the end result. Since the micro chipping improves each subsequent sharpening, I'm wondering if the reason for the chipping is the much larger burr that is formed on the first sharpening? Since I'm typically reprofiling, naturally the burr gets a bit bigger in certain spots on the apex, even though I try to hit specific areas at a time that still need work. When I sharpen the second and or third time the burr is much smaller on the 80 grit stone since I'm reaching the apex immediately.
Another issue I'd like input on is, I also have noticed I get a cleaner apex if I do only straight "up and down" edge trailing passes. But the scratches on the bevel end up looking "splotchy", not nice and uniform. The end result doesn't look very nice. When I add a slight horizontal sweeping motion the bevel looks very nice with a uniform scratch pattern.
Just wondering if anyone else has experienced these "issues" and can give me some pointers moving forward.
