Wal Mart seems to be selling this new Gerber lately for under $10. Folding utility knives seem to be quite common in the last few years, most pretty much like the Superknife, very similar to a generic folding knife with a utility blade holder in place of a regular blade. This Gerber seems to be a competely different approach.
For starters, it's quite small. Closed, it forms a thin, almost rectangular package less than 3" long. Finish is handsome bead blasted stainless steel with a wide pocket clip sporting the Gerber logo. A single, though not terribly useful, nail nick is machined into one side of the blade holder.
The stock blade is a heavy duty contractor's grade blade, held securely in place with a single Phillips screw. Upon close examination, the construction of the knife is quite clever, consisting of several layers of stainless steel sheet, each stamped it's required shape and laminated together. The clip appears to slide onto the end.
Opening the knife reveals a liner lock, smooth operation, and no play at the joint. One of the bladeholder's stainless steel laminations forms a convenient choil under part of the blade's edge. An interesting thing about this design is that the exposed cutting edge of the utility blade is significantly larger than any other utility knife I've seen using this type of blade. The tolerances of the blade holder seem pretty tight with the supplied blade. Secured with that Phillips screw, the blade has absolutely no play at all. Cutting heavy cardboard didn't loosen the blade one bit.
This is really a clever, compact design for a utility knife. Probably one of the better on the market. However, there is room for improvement. Most obvious might be a tool-less blade change mechanism. Any such mechanism should be clever enough to work with the knife, unlike most currently on the market which are clunky and/or not terribly secure. Another improvement would be a provision for one hand opening. I find it is possible to open the current design one handed, however, it takes a bit of concentration and reasonably clean, naturally moist, hands. I experimented a bit with a longer screw that protrudes out the backside, used as a kind of thumb stud. It works, but is clearly inelegant. A full length nail nick, cut deeper and sharper might do the job better.
I've been unable to find out much about this knife. So far, it seems to be sold only at Wal Mart. The packaging even has the counter display number printed on the box, perhaps for the time being, it may be a Wal Mart exclusive. Another curiosity is the patent numbers displayed on the package, which when looked up, seem to have no similarity with the EAB Pocket knife at all. Other patents pending, presumably for this particular knife, are also indicated on the packaging. Weighs about 2.2 oz according to the package. Has no provision for a lanyard. And it's made in China.
