New Leatherman Super Tool 300
.....was announced recently. It's a nice blend of features from the retired Super Tool 200 and the current Core model. They've just put up some nice photos of it on the Leatherman website. (displayed here with permission)
Apparently there are to be two versions; stainless finish as shown, and a black oxide model with cap crimper jaws. I can't wait to try one. :)
~Bob
Looks pretty cool. I'll be watching to see if this is the one that replaces my Powerlock or not;)
Looks interesting. I'm definitely interested, but not sure I want to go that heavy on a MT when I currently carry around a Charge TTi.
It is cool looking - but honestly I am starting to lose a little of my love for Leatherman. They do seem to be constantly upgrading their line - but the fit and finish seems to be losing ground every year.
The other problem I seem to have is the sheaths - I have an original Wave with the all leather sheath, and it is still kicking butt!! I cannot begin to count the "combo" leather / kydex and elastic sheaths I have ruined.
Hopefully there will be some good reviews on this one.
Hmmm, this might be exactly what I am looking for :D
A large multi that has tools that are easy to access :)
all the tools are still only open-accessible. i personally see no reason to get this, as it has no obvious advantage over the current line of LM tools.
really, what is it about closed-accessible tools that MT companies are so afraid of? they made the blades on the Wave, Charge, and Surge closed-accessible, so why not the rest of the tools in them?
There are advantages to an "open accessible" format. In dirty, dusty environments, the works stay cleaner than with outside access tools that are always exposed to mung getting in the spaces between blades and implements. It is also easier to use the multitool as an expedient tack hammer, if necessary; not advisable, but I've done it successfully on occasion with a Super Tool, later a Core. Also, the original Leatherman layout is straightforward simple, more likely to be reliable in hard use.
That said, I am hugely fond of my Charge TTi, but swap it out for a Core if I expect heavy duty work, nasty conditions or remote locations. The Charge is fine for most of what I encounter, but I have a bit more confidence in the Core.
That looks durn nice. I like the ST200 a lot, and this one is a bit more compact.
What is the weight and length compared to the Core, is the blades long like on the Core or short like on the ST200? What tools does it have?
RickJ
RickJ
It's 10.1 oz and has the following tools:
Super Tool® 300
420HC Clip-point Knife with Straight Edge and 420HC Sheep's Foot, Serrated Knife
Needlenose Pliers, Regular Pliers
Removable Wire cutters, Removeable Hard-wire cutters, Stranded-wire cutters
Wire Stripper
Electrical Crimper
Screwdriver 5/16", Screwdriver 7/32", Screwdriver 1/8", Phillips
Wood/Metal file
Saw
Bottle Opener
Can Opener
9 in | 22 cm
Awl w/Thread Loop
Here's the product sheet from The Leatherman Library:
And here's the press release:
Super Tool 300—the original heavy-duty multi-tool is back!
This fall, Leatherman will be bringing back Super Tool® with plenty of new and upgraded features. The new Super Tool 300 (ST300) will continue the long tradition of preparing the working man and DIYers alike, for the expected and unexpected.
The new ST300 has more than 10 years of compiled customer feedback and engineering expertise in every feature. Each one is designed to address the user who demands strength, quick access to tools, and comfort for tough jobs.
Arguably the most important feature of the ST300; the pliers have been optimized for strength. To maintain the balance of materials when making room for the new removable wire cutters, more steel was added to key areas, making them the strongest, beefiest pilers we’ve ever produced. In addition the neck of the pliers is sloped for reaching even further into tight spaces.
Cutting wire—regular, stranded, or hard—is a common application on the job. When frequent, heavy pressure is applied, cutters can become dented and dull, causing the pliers to stick and jam up. By making the regular/hard-wire cutters removable they can be sharpened or replaced on the spot (replacement cutters sold separately). In addition, by optimizing the heat treatment process and replacing the standard stainless steel with premium 154CM the wire cutters will hold an edge three times as long for maximum durability.
The idea of “clumping” was originally introduced with the first Super Tool. By pulling on only one tool, you would get them all from the handle at once, including the knives. To improve on safety, the new ST300 has just that, “Edge-safety Clumping”. If you pull on either of the two knifes they are the only implement that will come out. Conversely if you pull on any of the other features the sharp-edged ones stay put.
The ST300 straight blade is hollow ground for easy sharpening. Screwdrivers are in the sizes professionals use most and are also hollow ground for a better fit. The handles are rounded for comfort and have cut outs on the side to easily access blades when wearing bulky work gloves. The locks on the ST300 have been strengthened to ensure full engagement when the features are under heavy use.
ST300 will ship in September 2009 for distribution worldwide and will come with Leatherman’s industry-leading, 25-year warranty. MSRP for the ST300 will be $84.00 (USD). A black oxide version with cap crimper will also be available at an MSRP of $97.00 (USD).
History of the Super Tool
The original Super Tool was introduced in 1994. The first multi-tool of its size and strength, it was an instant success selling more than one million units in the first two years alone. In 2001 modifications were made and the Super Tool 200 hit the market. The new ST200 featured moon-shaped locks on the handle sides, instead of the original all-in-one locking system. Customers still raved about the tool’s strength and many applications, but the locks and “clumping” were not as user-friendly as they would have liked. Enter the Core®.
In 2005 Leatherman revised the ST200 putting new locks on the back sides of the handles and doing away with “clumping”. The jaws were also re-designed for strength and the new tool was called the Core. Underestimating the popularity of this new tool and how quickly it would be adopted for every day use on job sites the world over, the lock design and tool accessibility was not what it could be. Fast forward to 2009 and the Super Tool 300. This new design, specifically for heavy-duty, on-the-job use is sure to find its place in tool belts, gear boxes, saddle bags, MOLLE vests, and center consuls the world over.
About Leatherman
Founded in 1983, Portland, Oregon-based Leatherman Tool Group is known for producing the world’s most precisely engineered multi-tools, knives, pruners and lights. Leatherman’s engineering standards remain unmatched in the industry today. With new products for trades, hunting, outdoor, fishing, gardening and general purpose, the Leatherman tradition of innovation, tight specifications and premium materials continues to endure.
Not sure what to think about this tool. I've had about a month to think about it (it was announced here back in May: http://forum.multitool.org/index.php/topic,11095.0.html), and I'm just not sure. Other then the wire cutters, it's just a Core with an old style body. Not very innovative. And it's SOOOO big. Yeah, it'll be able to dismantle the Titanic if need be, but..... I don't know. Just not enough to make me want to replace my Wave.
"Underestimating the popularity of this new tool and how quickly it would be adopted for every day use on job sites the world over, the lock design and tool accessibility was not what it could be."
I've got a Core and that isn't a ringing endorsement from Leatherman! Wonder if they will swap it for a ST300:D
My take on the ST300 is to think of it as an improved version of the Core. Same basic size, same exact blade selection, but with improved knife blade access and a more capable plier head.
I also like that they've gotten rid of the plastic spacers. :) Not that I've ever had the plastic fail on my Core, but there's just something more confidence inspiring about all-metal construction.
Bob
Too bad they didn't include a pair of scissors, that would have been perfect. I still want one of the ST300's, but I guess putting scissors in it would make other Leatherman models obsolete.
I've got one of the older Supertools and love it. Yeah, I knw it's big, but I don't go anywhere without it in my bag. Heck of a tool in the field.:thumbup:
