Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I thought the torx size for PM2 pivot screws was T10...
The pivot screw on the Blurple S110 Millie is a #8X32TPI wafer head screw with a #15 TORX recess. The length under the head is about .170" or 11/64th. The dingus on the other side of the pivot is a slab sided T-nut that is not supposed to turn in the hole. Even though the T-nut has #15 TORX recess, DON'T TRY TO TURN IT. The T-nut on my knife is on the clip side. You can use the TORX bit to hold the T-nut while you loosen the pivot screw. That might save wear and tear on the D-holes in the liners.
.1875" is 3/16". You can shorten the screw by grinding it with a nut on it and restoring the thread by backing the nut off.
The Klein 1001 electrician's pliers has a screw cutter built into it. Looking at Albany, I think you want the TORX pan head screws in 18-8 stainless steel. If the head is too large, you can chuck up the screw in an electric hand drill and spin grind it against a grinding belt or wheel.
Flat head screws are measured from the top of the head to the end of screw. Pan head screws are measured from under the head to the end of the screw. I don't think you are looking for a flat head screw for the Millie pivot.
The screw I think you want is a #8X32TPI pan head 1/4" long or longer since you will probably be trimming it to size. The pliers mentioned above make trimming an easy task. The composition of the screws in the Albany list is 18% Chrome and 8% Nickel. 18-8 stainless steel is highly resistant to corrosion and is often used in cookware.
