New Mora Bushcraft Line - Early Impressions
I have gotten my hands on both the Triflex and the Sandvik version of the new Mora Bushcraft series. These are the ones with the traditional Mora blade geometry...not the "dramatic grind" of the 2000 and 2010 models.
Lets start with the cons.
1. Ain't none. Some people won't like the funny green color but I do.
Pros
1. Fantastic handles. I am not sure if they are any more deeply imbedded tang-wise than the Craftsmen series but I've never had a problem. The grainy rubber-like surface is great and the shape is superb.
2. Blades. What we have all come to expect from Mora. Plus, the Sandvik is the same thinkness as the Triflex making both very solid, if not exactly beefy blades. Razor sharp scandi grinds right from the box.
3. Fit and finish. They have polished the spine which is nice although it may not server as a fire striker as well. The blades are set well in the handles with no gaps.
4. Sheaths. Yes, that's right, sheath as a Mora pro. Maybe it's just what we're used to but these plastic sheaths seem like they would be usable and are not just packaging. There is a proper belt loop instead of the slots and the button hote. The belt loop is some sort of rubber-like material for flexibility...not the same stuff as the sheath.
5. Price. Always a Mora selling point. Just a few dollars more than their regular stuff.
Testing
Haven't got them outdoors where the true test begins but I am in the midst of some leather projects. I used each one to cut thick vegetable tanned leather and they zipped right through. If any thing the edges are sharper now...probably de-burred them a bit. Stood up very well to this initial test. Gripping the handles firmly was easy because they are kind of cushy.
Mora continues to be the best value in knives, IMO. They have only enhanced that position here.
Regarding comment #3, you will be pleased to know the new Triflex with polished spine works well with the fire steel. I am having no problems getting plenty of sparks from a goingear misch metal steel. If it works on M/M, it will work on darn near anything:)
Great review. I agree with your observations but add that the spine on my Bushcraft Triflex throws a good spark with a ferro rod.
Also, I learned in another thread that Triflex is layered and differentially tempered. Plus the core of Triflex is the Swedish equivalent of O-1.
Here is a pic of the older 780 Trifex (bottom knife) with the new Bushcraft Triflex and sheath.
I tested a "proto" version of 2010, it's as good as the ol' 2000. :thumbup:
Received my Mora Bushcraft Force from Amazon last week and though I've only done some minor whittling with it, I have to say I am very impressed. It's basically a Mora Allround with a better handle, much better sheath and a wider blade. I've used the the Allround a bit so I'd say the Buscraft line is a homerun being as it is even better then the Allround.
I have a Mora Bushcraft TriFlex and like it a bunch. Came crazy sharp and better finished (no grind marks etc) than my other Moras.
Compared to the rather nice Mora 746G for size etc.
