New Smock - Titanium Scales
Tensaw
I would like to replace the aluminum scales on my new Smock with titanium. The Meton Boss scales are made for the older pivot, but they offer a screw kit to make them work with the newer version. Does this work ok? Are there sources I should consider? Thanks for any info.
I’ve got a lot of his scales (zirconium, titanium,and aluminum) for different models…all well made. My Smock is the older pivot so no experience with the screw conversion. Pretty sure he offers assembly if you send the knife to him. Don’t know of anyone making scales for the new larger pivot yet. Good luck
Thinking about this a little more and looking at the newer smock CruWear, I realized his conversion will just be a smaller screw like mine pictured. No way Spyderco made a larger pivot..just added the decorate screw with bigger recess into scales. You should be good to go! IMG_0363.jpegIMG_0364.jpeg
Thinking about this a little more and looking at the newer smock CruWear, I realized his conversion will just be a smaller screw like mine pictured. No way Spyderco made a larger pivot..just added the decorate screw with bigger recess into scales. You should be good to go! View attachment 2889296View attachment 2889297
That's what I'm talking about! Yes, MB's kit is 2 pivot (smaller) screws only, so I assume pivot barrel size is the same. I think you're right and it should be fine. Now I just need to pick some out. Thanks for your input.
