We're about to offer this unit for sale on our web site. We've been researching this for some time and just recently nailed down what we wanted. It is capable of running small 2 way radios and scanners as a stand alone unit, or can charge just about any device rated between 6 and 12 volts. I've been using it to charge digital camera batteries, 1.5 volt AAs (4 at a time), and for operating radios.
Jungle Charger Information Sheet
The Jungle Charger is the most compact, high output portable solar charger on the market. It was specifically designed to charge 6 - 7.5 volt systems or four 1 ½ volt batteries in remote locations. It has a 7 volt @ 250 ma output in full sunlight. It will put out less than that under other conditions but will still be charging your device. It has a built in Blocking Diode to prevent current from discharging back through the solar panel when the plug is connected and there is no light available. Two Jungle Chargers can be combined with the Junction Box (sold separately) to charge 12 volts systems or charge 6 volt systems with double amperage output.
The Jungle Charger has a DC power plug enclosed with 3 feet of cabling. The plug is a standard 5.5mm O.D. x 2.5mm I.D. and can be changed or adapted to suit the end user's needs.
The wire and plug can be placed inside the foldable hard plastic box when not is use making this the only solar charger that can do this and at the same time be able to still fit inside your pocket for easy carrying.
The solar panels are completely waterproof and weatherproof.
Size specifications: outside dimensions not including hinges and latch
Closed: (storage and carry position) outside box dimensions not including hinges and latch 2.25" x 5.88" x .688"
Opened (charge position) 5.75" x 5.88" x .34"
Jungle Charger Junction Box
The Junction Box is designed to couple two Jungle Chargers together to either increase the amperage output when connected in parallel, or increase the voltage output when connected in series. The Junction Box is capable of charging just about any small device by adapting the output plugs. When plugged into the Omni Source Universal Charger base it will charge nearly every 3.6 volt and 7.2 volt video and still camera battery on the market, including Sony, Panasonic, JVC, Hitachi, RCA, Canon, and Sharp.
Directions for 6-7.5 volt charging:
Connect each Jungle Charger into the jacks marked "Parallel Input" and connect your device to be charged or operated into the 6 volt output cord. In full sunlight this will produce a charging current of 7 volts @ 500 ma. The supplied power jack on the 6 volt cord is a standard 5.5mm O.D. x 2.5mm I.D. The user can change or adapt the plug to fit the unit to be charged being sure to observe correct polarities.
Directions for 12 volt charging:
Connect each Jungle Charger into the jacks marked "Serial Input" and connect your device to be charged or operated into the 12 volt output cord. In full sunlight this will produce a charging current of 14 volts @ 250 ma. The supplied power jack on the 12 volt cord can be changed to fit the unit to be charged, however this is a standard 12 volt charging jack.
If this Junction Box is used with solar chargers other than the Jungle Charger then it may be required to place a blocking diode within the circuit. The Jungle Charger units already have blocking diodes built in.
This photo is not that great but we will have good photos up on the site soon.
