Yeah, sickpuppy knows what he's talking about. Increasing the AC input voltage would be asking for trouble. To simplify the circuit a bit, the DC controller makes DC power from AC by using a rectifier, which cuts off or blocks the negative voltage side of the AC, leaving all the positive voltage in a series of sinusoidal pulses. Smoothing capacitors are then used to level out these pulses to a closer to constant DC voltage, then the output is controlled by using PWM to reduce voltage to slow the motor.
Increasing the AC voltage in would also increase the DC out, but again, just like the motor itself, the components in the DC control circuit are built for the rated input voltage. They normally have some degree of safety margin for over-voltage, but nowhere near 200%! As already mentioned, you'd be looking at instant catastrophic failure of the circuit if you tried that. Not probable, definite.
What I meant by the "increased voltage" I mentioned earlier was increasing the DC output voltage, which would require a higher voltage output DC controller. So if you had a 90VDC rated motor, you'd purchase a 180VDC rated controller. The motor would run just like normal from 0-90VDC and achieve it's rated 1800 RPM. Turning the DC output up from there would increase the RPM by the same percentage as the voltage increase. So taking a 90VDC rated motor thats RPM rated at 1800 RPM and instead running it at 180VDC would result in 3600 RPM. However, it could also fry the motor, and would at the very least cause severely accelerated brush and commutator wear. Would get a lot hotter than it should also, and if it got hot enough would short the armature wiring and probably fry the controller.
