With good technique (very light pressure, consistent angle control), I'd say you're right, as compared to other 'hard' stones/hones I've used. Diamond cuts so cleanly, that even feather-light pressure is enough to work. On less-hard abrasives, especially when used in stone/hone form (sandpaper & loose grit aside), a little more pressure would be needed to make them work as aggressively as diamond. Pressure is what makes the difference with burrs.
I've really grown to like using diamond for the reason above. I've finally found a touch that works very well with it, and results are getting way better for me. This means I'm getting very crisp edges and minimal burring, to the point I often don't even feel the need to strop afterwards. The same improved touch is also yielding better results on all other hones I'm using (SiC, AlOx, ceramic, Arkansas), so I know I've found something fundamentally sound.
I mentioned good angle control above, because with edge-leading, any tendency to roll the blade (and apex) forward into the hone will greatly magnify the force exerted against the apex, and therefore increase the likelihood of burring, or generating heavier burrs. Part of the improved 'touch' I mentioned above, has been in finding a steady way to hold the blade & hone while working, which both minimizes any tendency to roll the blade forward, and also maintains the pressure at a very light level. I think everybody should really pay attention to how they hold the blade (and hone, if not used on the bench), and stay aware of how that is affecting angle control and pressure. It really pays off big, when a means is found to control those two variables in a consistent and repeatable manner.
The reason I mentioned the ease of edge-trailing on sandpaper (specifically), is because it's MUCH more forgiving of inconsistencies in angle control and pressure (to a finite point). When I first started using sandpaper, my own technique was still in need of 'improvement' (ahem), but I still noticed it was much easier to minimize burring and produce some pretty good edges; that's what got me hooked on that method in the first place, as it was working better for me than anything else I'd tried 'freehand'. In fact, I think that's what finally started to 'liberate' me of my dependency on guided sharpening at the time, so I was thrilled.
David
