Back and forth without leaving the stone or one pass down ,lift off at the end and reset at the front of the stone?Work it on the 150 grit holding a consistent angle with some pressure. You'll form a burr. Flip it over and do the same.. DM
What angle?"Feels almost round just behind the edge" suggests the held angle is varying too much.
If so, it would prevent the apex from becoming crisp and would at least partly explain why a burr hasn't formed yet. The held angle must be fairly consistent, to thin the edge enough to form a burr. Otherwise, the variability in held angle will keep rounding off the apex and the burr never forms.
What angle?
He means the angle you're holding the knife relative to the stone. Mark the bevel with a Sharpie, it will help guide you.
Ok i just did the sharpie.I think i must of really messed up the factory bevel on this....the sharpie like rides a ridge the whole way down the bevel and theres like a steep wall from the top ...its like theres edge,then angle,then steep wall up onto the flat of the blade.He means the angle you're holding the knife relative to the stone. Mark the bevel with a Sharpie, it will help guide you.
No I mean what degree I guess, sorry.
Feels almost round just behind the edge.
I got the sharpie off the one side but i still can't feel a burrMark the edge bevel with a Sharpie and take a picture.
Grind on your stone and take more pictures.
Upload them to Imgur or similar and then post them here. It will help us to see what is happening.
this sounds like what i think is going onMaverick1, I can't say for sure but it sounds like the area behind the edge might be too thick and you are hitting that instead of the apex. If that's the case I'd thin that area out. Thin edges cut a lot better than thick edges. Again, if that is the case I'd use the 60 grit Baryonyx Manticore instead of a 150 grit abrasive unless you like to spend more time than necessary grinding away metal.
I often find factory angles to be too obtuse so don't pay any attention to their edge bevels, just sharpen at as low an angle as I can without the edge chipping or rolling doing the most demanding task I would use the knife for.
Where do I post pics?I got the sharpie off the one side but i still can't feel a burr
And yes i have been applying pressure on the return stroke so maybe ive just been rounding it this whole timeWhere do I post pics?
