Comprehensivist
Platinum Member
- Aug 23, 2008
I have posted positive comments about my Nomad several times over the years. Its primary role has been as a compact kitchen knife that goes in my travel kit on almost every trip away from home. It has served me well on the road in a world that is predominantly filled with cheap dull knives.
The thin 1/16” CPM 154 steel and G10 handle with good finger clearance over a cutting board make this an efficient cutting tool that is easy to maintain in damp, wet, or sticky settings. Just rinse and dry and pop it back in its kydex sheath until next time.
While I enjoy using this knife, I always felt there were a couple of spots where the handle could be improved to make it more comfortable in my hand.
The first is the position and shape of the bump on the bottom of the handle. If a knife has a distinct raised bump in this area, I want it to rest between two fingers rather than act a pressure point under one finger. The bump on the Nomad rests right under my middle finger, which is not comfortable.
For this reason, I decided to get out a small single cut file and some sandpaper to soften and round-off the point without removing the original form completely. This subtle change minimized the pressure point feeling under my finger.
The other area that bugged me was the flared shape and squarish corners on the back end of the handle. Many knife makers like to incorporate hard lines and/or squarish corners on the front and back ends of the handle to add visual contrast between curves and lines. It also highlights their knifemaking skills. I get that from an aesthetic or collector viewpoint. From a user perspective, harder lines and squarish corners add nothing desirable to the party for me. That is especially true on a small handled knife like the Nomad.
My solution was to remove the corners and round-off the pommel for a more comfortable and natural fit in the center of my palm.
After I was done with the reshaping and polishing, I masked-off all of the steel and glass bead blasted the handles one side at a time. I went with a slightly coarser texture than Chris normally does for a little better grip in wet conditions.
I am happy with the way it turned out because one of my favorite little travel knives has become even more user friendly. That is a good thing in my mind.
I understand that not everyone will appreciate or agree with these modifications. That’s perfectly fine. Feel free to comment; good, bad, or indifferent.
I would like to hear a variety of voices share their preferences on handle design in general to spark some interesting discussion. Please feel free to add your thoughts and opinions on the subject.
Thanks,
Phil
Thanks,
Phil
