Here's a bit of info of direct use
"Lignin melts at elevated temperatures [> 90° wet, > 160° dry"
[C-degrees I'm certain // that's >194'F & >320'F]
[so below the burning point of wood]
another source:
http://www.fpl.fs.fed.us/documnts/pdf1990/caulf90a.pdf
says "whereas isolated dry lignin softens at a temperature close to 200°C, in water its transition is lowered to about 80°C - 90°C.
Hemicellulose is even more moisture-sensitive; soften at about 55°C at a moisture content of 23%."
& with lots of info to follow up on---
something I've been meaning to do for a couple of years
French Fried Bamboo
"For the adventurous, there's an intriguing wood treatment which bypasses most of the traditional bamboo drying/treatment processes and that's to french-fry the green culm in hot non-catalyzed tung oil. Cut the culm and drill out the nodes. Heat a tube of oil to about 350 F. Introduce the green culm. When all boiling and other activity ceases cut the heat and allow the oil to cool with the culm submerged.
Here's what happens: All moisture is expelled as it's turned into steam and escapes as bubbles. All lignin in the wood is hardened as the oil temperature is above its hardening point. All the surface waxes will be melted and removed. During the cool-down period any air which was greatly expanded at 350 F. contracts and atmospheric pressure drives the oil into the wood. Wipe all excess oil from your culm and submit to the standard 3 month drying period.
The result will be bamboo which has had it's starches and sugars stabilized, all moisture removed and be thoroughly impregnated with hardened linoxyn. The wood will be markedly hardened and strengthened--being waterproof, dent proof, etc. The modulus of elasticity will drop considerably and the material will become even more rigid and 'musical'. The major component of a Stradivarius violin is the treated wood of the top plate. It's acoustical properties are what we recognize as exceptional sound. Once the culm has cured, craft a flute in your usual manner."
http://www.navaching.com/shaku/oil.html
http://www.inbar.int/publication/txt/INBAR_Technical_Report_No09.htm
"The essential step involved in oil-curing is to keep the rattan stems immersed in an oil medium just below boiling point for a certain amount of time - 5-10 to 30-40 minutes, depending on the species and diameter. During this process, waxy materials, gums and resins will be dissolved and therefore removed from the cane, and the moisture in the cane will be reduced. The superfluous oil is immediately rubbed off from the cured rattan. "
misc other references that have some related content/info:
http://scholar.lib.vt.edu/theses/available/etd-112399-131003/unrestricted/03ch2.pdf
http://www.ingentaconnect.com/content/vsp/jbr/2002/00000001/00000004/art00005
http://www.nasaexplores.com/show2_912a.php?id=01-061&gl=912
> THEY call me 'Dean'
-fYI-fWiW-iIRC-JMO-M2C-YMMV-TiA-YW-GL-HH-HBd-IBSCUtWS-theWotBGUaDUaDUaD
<> Noobee <> Tips <> Baha'i Prayers Links --A--T--H--D
