Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Nope. Everthing in moderation.I believe you have that reversed Travish.
In finishing a new blade, you start with low grits and work higher, making it shinier and shinier.
A mirror finish is typically 2000 and higher. And it doesn't take much to 'dull' it.
So you simply reverse the process and start with a high grit and work lower, making it duller and duller.
Scotchbrite pads are usually 400 and lower, depending on color. That's a large jump from 2000+.
There are lots of ways to get rid of a mirror finish. We can give better recommendations if you tell us the finish you want.
I'd just like something that didn't reflect as much. A dull flat finish, optimally
Thanks for all the responses!
That sounds like a Scotch-Brite finish, to me; should be the easiest as well...
David
Can you not use steel wool as well?.
You could do a stone wash or an acid wash pretty easily and the mirror sheen would disappear.
The reason to start fine and progress to coarser grits is so you can stop when you like what you see. If you go from mirror finish directly to 400 and decide it is now too rough you have a long road back. Each step from fine to coarse (getting rougher) is easy. And fairly easy to reverse, if you are only trying to go back one step.
