Jeff Clark:
<font face="Verdana, Arial" size="2">The edge bevel is a distant memory so there is no issue of tracking the original grind. </font>
Yes, of course, if you have to create an actual edge bevel then it will take you much longer than a few minutes. On a hone this could easily be hours, even with a very aggressive abrasive, 80 grit SiC lapping compound.
Fact is, it is even worse than that. If there is that much wear on the blade (10+ years of use), you can't just create an edge bevel because if you did the profile would be far too thick. Unless the primary grind is a deep hollow, you are going to want to work a little on the primary grind.
However this is more along the lines of restoring a knife than sharpening it, and far from the situations that questions on sharpening are addressing. You would take a month to do this with the Sharpmaker for example, yes it is one of the most often recommended "sharpeners".
As noted in the above, using the correct abrasives, assuming correct geometry and design, sharpening even a really dull knife (~1-2% of NIB cutting ability), is only a few minutes of work even on the worse steel.
In regards to my experience with heavy use knives, I have reconditioned many old knives. Kitchen knives with 40+ years of service, a chefs knife steeled that much it has wore into a fillet blade for example.
On something like that I will usually lower the primary bevel and restore the secondary. This will take quite some time, mainly to insure that the blade doesn't overheat.
Same thing with restoring old and/or abused woodworking tools, chisels for example that have been used to cut wire. You might have to move the bevel back as much as 1/8" which takes a very long time.
However as I said, I really don't consider that "sharpening" as it is far too extreme a case, far beyond the situations that questions on sharpening are meant to addressed. These usually mean "when my knife gets dull, how do I restore it", not "I have worn the entire edge bevel off of my knife, how do I regrind it".
-Cliff
[This message has been edited by Cliff Stamp (edited 06-19-2001).]
