I’ve picked up many neglected SAKs over the years and none were wore out. Some were seized up tho and needed an overnight soaking to free the blades and tools up. Because of that, mine get a drop of oil to keep things smooth.Does oiling or not oiling make any difference with regards to wear?
Probably more cleaning, get the grit out as it will add wear. Yes oiling does help but you don't need to go over board. Every so often give a bit of TLC.Does oiling or not oiling make any difference with regards to wear?
It will reduce wear a little but it would be very hard to measure the difference. Oil is always good. Just don't over do it.Does oiling or not oiling make any difference with regards to wear?
