- May 13, 2012
Last week I ordered both a 1st gen and 2nd gen ZT 0550. The 1st gen came first and the lock up was perfectly smooth just my 0301 and 0303. I did notice that the detent and pivot was a little tight as I had heard so often about the 1st gen models. All in all, I was very pleased and couldn't wait to get the 2nd gen.
The 2nd gen showed up on Tuesday of this week and I noticed that the detent and pivot were much more smooth. The only 'problem' so-to-speak was that the lock up stuck.. bad. I had a similar issue on my 0560 when it was new but after a day of playing with it, it broke in nicely. This 2nd gen 0550 has been a bear all week. If I flip it open hard, it unlocks easily enough but if I open it controlled and allow it to click right in it locks up to the point where I usually cant even unlock it without using a makeshift prybar (I was using the flat blade on my swiss army knife to release it).
I have spent 3 days working on this and it was just not breaking in any further. I was to the point that I was probably going to call Kershaw and have it sent in for repair... doing some searching, I found recommendations of putting pencil lead(graphite) on the lock bar surface and blade contact surface... this didn't make any sense to me, but I figured I would give it a shot before I sent the knife off.
Well, I grabbed a mechanical pencil about 30 min ago and got started. I put as much as I could on there without it just falling off and worked it for a little while. It seemed to actually be a little easier, but still a bit tight. After 50-100 opens/closes I reapplied the pencil and kept going... It seems that it's completely worked itself out. I'm rather shocked. Is it just a small bits of graphite sitting in the machining marks that are allowing it to slide? Am I going to have to reapply the pencil after it eventually comes off or is this a permanent solution that somehow allowed the surfaces to mate properly?
I'm thrilled that this worked... I just don't really understand WHY it worked. Any help would be awesome. Thanks guys!
