- Aug 4, 2013
The switch to 1075 carbon steel from 1095 carbon steel on the majority of the OKC SP series, (non Gen2), is said to have been done 2-3 years ago. The following is a post put up by Paul Tsujimoto (Toooj) recently on this forum. It gives a short bit of insight into why the decision to switch was made. This is not being put up by me to debate the pros and cons of their decision, but only to share the info again so that folks that had not read this before, can now be informed about it...
We do a lot of metallurgical testing and review concerning the type of steel and properties and how it relates to quality issues. We have come to the conclusion that 1075 is a better steel for the vast majority of our knives. 1075 still has sufficient carbon to produce a nicely hardened blade, it has good edge retention and it also has a lot more toughness to hold up to the impact that working knives (machetes) see on a continued basis. That is the reason for the change. Our Military contract knives still will use 1095 but any knife/tool that is not under specification has been changed to 1075. I think you will find a lot less chipping and breakage with the 1075 steel. Dan Maragni and I could bore you with Metallurgical mumbo-Jumbo but ultimately we like not having to deal with broken blades under warranty and we think you will also.
Hope this helps.
Best Regards,
Paul Tsujimoto
V.P. of Engineering
Ontario Knife Comapany
Hope this helps.
Best Regards,
Paul Tsujimoto
V.P. of Engineering
