- May 1, 2011
Hello, I have been recently using "stock removal" to make some broad heads out of old hand saw blades. I had several old hand saws laying around which seemed to be made of high carbon steel due to the hardness, and the large sparks when grinding with an angle grinder to shape the broad heads. They are first cut off in blanks off the blade of the hand saw with tin snips. Then ground into shape with an angle grinder and I put a chisel ground blade on the broad heads with 4x36 belt sander with 60- 220- 400 "grinding belts" atleast as good as they get for a 4x36. They seem to take a nice edge and I have not yet heat treated them because I made sure to keep them from changing colors during shaping. I was going to attempt a few knives from the saw blades being that I have a few. I would like to know if anyone has an opinion on what type of steel these old hand saw blades were made from? I would like to know how to properly heat treat the blades, but I do not know what type of steel they are. What are opinions on using a chisel ground blade?
