- Jan 2, 2014
Hey Everyone. After checking out the forums on bush knife reccomendations and seeing the 7" Old Hickory Butcher knife pop up over and over again as a good option I picked one up. The modifications I made were pretty straightforward:
1. Pop off scales
2. wet Sand metal under scales with wd-40 - like most noted there was indeed a fair amount of rust under the scales.
3. Sand handle scales to make them less blocky
4. Treat scales with boiled linseed oil - I did 3 coats
5. Hit the blade with bore cleaner to remove any unseen particles
6. Epoxy the treated scales back onto the blade and attach the original rivits.
7. Polish blade with high grit sand paper and hand sharpen on wet stone up to 6000 grit.
It was a pretty easy process and had pretty good results, I'll post pictures when I can but it's really nothing fancy. What I'm especially curious about though is folks who have ground the blade down to 5" or so and shaped it into a kephart blade shape. I feel like that amount of grinding would ruin the temper on the blade given the massive amount of sparks and heat that must be generated. Has anyone had experience grinding these blades into different shapes, and if so have you noticed whether or not the temper appeared to be affected?
1. Pop off scales
