ferider
Platinum Member
- Jun 20, 2018
I’ve (dis)assembled > 100 folders over the last two years, and in the process adjusted how I work with thread lockers. Proper use is important as I don’t want to keep readjusting my knives. Also, as I have watched Youtube videos and other user’s comments, I felt a dedicated thread would be in order. I hope this is the right place. Otherwise, moderators, feel free to move, of course.
There are many different types of thread-lockers, plenty of Chinese and Korean fakes, etc. Today, I only use the real stuff, in particular
Here is what I do with them:
Thanks for reading,
Roland.
PS: charts are from the manufacturer (www.loctiteproducts.com)
- Purple Loctite (222)
- Blue Loctite (242)
- And Red Loctite (262)
- Use purple/blue/red depending on the screw size. For example, purple is more than plenty for T6 or similar small screws (e.g., clip screws).
- Use different color depending on the screw type. For example, a Hinderer small (scale) allen screw will strip much easier than a small Spyderco T6 torx screw from Colorado or Japan (Spyderco Taiwan and China screws appear much softer).
- Whatever color I use, a loose screw – even after being “thread locked” - will remain _much_ looser than a thread locked tight screw.
- To disassemble (in particular for red), you need localized heat greater than 550° F. I don’t really like to use a soldering iron as it’s hard to keep a screw unmarked, and difficult to get high temperature quickly. Easier to use a gas flame, when I can avoid to burn a scale, etc. LT is quite heat resistant; for example, this is for 262:
- Keep the screws clean. When assembling a folder there is oil, it gets pulled easily into pivots, fingers get greasy, etc. Don’t touch screws with your hands, use tweezers instead. Sometimes an acetone (nail polish) cleaning is required, etc.
- Once LT is applied, I give myself about 10’ max. for manipulation/tuning of a knife. In particular red LT dries up quickly, and if I mess around – say with a Pivot action – too long, thread locker will be worthless.
- And finally the most important part: let LT dry at least 24 hours without touching the knife. These days I use 48 hours, typically. As an example, here are 242 curing times, for different materials:
You can see that, e.g., for stainless screws in a stainless pivot or standoff, after 24 hours, 242 barely reaches 25% of its full strength (admittedly, an M10 Pivot screw is quite large
- but you get the point ...). If you are impatient, you can accelerate curing with heat (e.g., put it over night close to your heater or similar), like this:
Thanks for reading,
Roland.
