Ontario SP8 Machete Survival
It's time for another outdoors knife; one that can really chop some stuff down. So I bought the Ontario Machete Survival knife, model SP8. It costed me about $55, and is US-made. How does it work? Very well, as you'll see. Here are the details...
Handle Details: The handle is 5-1/16" long, and has both a pommel and a single guard. This gives you an actual usable handle area of 4-1/2".
The hanlde is made of black Kraton, which has ridges for good grip. The butt of the handle is lined with a brass lanyard hole, and it comes with a black shoestring-type lanyard already attached. The handle encases the blade for about 4/5 of its length, so while it's not a true full tang, it's pretty darn close. I love this handle, it's very secure. There's no way I'm going to lose this knife when chopping, even without the lanyard.
Impressions: Wow, this is quite comfy compared to other choppers I've used. I'm so glad they didn't put a guard on the top of the handle; it's not necessary and I think it gets in the way. I love this handle type and I wish more knife maufacturers would use something like it instead of hard plastic or rough wood. Yes, they look nice, but they really hurt the hand when chopping with them.
Blade Details: The blade is made of 1095 carbon steel, black powder-coated to resist rust and corrosion. It's 10" long, but the actual cutting edge is 7-3/4" long. The blade is rectangle-shaped in that it has no point; the "tip" is squared off. The back of the blade has a sawback that's 6-1/8" long. It's textured a little bit too coarse for my liking as a saw, but it's great for notching. Oh yeah; this blade is 1/4" thick. Yes, a quarter of an inch thick. The "tip" is also sharpened like the edge, but much more dull. The cutting edge came out of the box sharp enough to slice paper, but the tip was really dull. I think I'll leave it as is; it would maek a nice prybar if I really needed one. The blade is flat ground starting about 2/3 of the way down and it has a secondary bevel. The blade is 1-7/8" wide too, and this is for its entire length.
Impressions: Whoa, this sucker is beefy. Not only is it thick, but it's wide too. I don't have a weight for it available, but it's heavy. A chopper should be heavy. The balance point on mine is about 2-1/2" up on the blade. Not too bad, and in fact I like a blade-heavy knife when I'm chopping. This thing excels; it cuts easily and without a lot of effort. It will saw if needed, but I find it easier to chop unless you're needing precision work. As a prying tool, it works just fine on hard wood. No bending, no breaking.
The Sheath: It's made of heavy black Cordura and black leather. The sheath is different from most other sheaths; the knife has to unsnapped and removed from the side. On the side, there are three snaps attached to a leather flap, and they attach to snaps on the front of the sheath. I'm assuming this is so the sawback doesn't shred your sheath. You also get a standard snap that goes over the back of the knife, but it's not really needed. You cannot remove the knife from the sheath without undoing the sides first; a portion of the top of the sheath is sewn (and riveted) together. They really don't want you ripping up that sheath! The sheath comes with a plastic D-ring that has some more black shoestring cord attached. I find this breaks off when used as a leg tie since it's plastic, so I cut mine off when I get it.
The sheath is attached to your belt via leather belt loop. And guess what... it's a dangler sheath! The leather loop attaces to the leather on the sheath, and there's no plastic involved. The D-ring that acts as the dangler is blackened steel. Why couldn't they do this on the leg tiedown ring? The belt loop will accomodate a belt up to 2-1/2" wide. This is nice if you're wearing a pistol belt, but if you're wearing a normal belt the sheath can move around due to the loop being so wide.
Well, I think this is probably one of the best "survival" knives you can find. It's thick enough to chop with, gives a minimal approach to sawing, comes very sharp, is made of good carbon steel, and has a nice grip. The sheath does its job, and I'm glad to see they used a method of housing the sawback in a way that minimizes sheath damage. This is definitely worth the $55 I paid for it, especially considering this is an American-made knife. Great job Ontario :thumbup:
Very good review of a very cool knife.
Looks like something that wouldn't mind riding under the seat of a truck.....or an airplane.
Thanks for the review.
I've had one for a couple of years as well. I stripped off the coatings and put a nice vinegar patina on it. I've beat it pretty bad and it has performed nicely.
I've had one for over 10 years. I heat my home with wood,and I use it to chop my kindling. I have absolutely beat the hell out of it,and it takes it right in stride.
I don't go out of my way looking for ways to abuse/destroy this or any tool,but it really is a no nonsense "get 'er done" tool.
Alex
I wonder how it would fare against a Becker TacTool or a CRKT Razel?
The SP8 has been around for a while - at at half the cost of the Becker or Razel.
Nice review. Been thinking of getting one of these... I have a friend who swears by his, and doesnt carry any other blade....
Stay tuned; I'll be doing a comparison between the SP8 and the Razel soon.
Thanks for the review & I'll really be interested in the comparison of it with the Razel.
I've had my SP8 machete for a # of yrs now & it's great. It's seen quite a bit of use around the yard & my friend borrowed it & was very impressed. He kept checking it out, lol. He's also a landscaper, so while he's a friend, I had to quietly put it back in the garage, lol.
I've had my SP-8 for years also and it makes a great camping tool. Easy to sharpen and we've used it for all kinds of digging and chopping chores. For once, I like the factory sheath that it comes with, just removed the lanyard and the lower plastic ring. Not bad for like $50.
I almost bought one years ago, but went with a conventional hatchet instead. I still want one though - I wish it didn't have the sawback.
I just received an sp8 tonight and went out and wailed on it... I agree with the review, it is a great tool. I don't understand the purpose of the saw, but everything else I love. I only had to give $31 brand new....how do you beat it. It is supposed to have a manufacturers flaw, but I have not seen it.
Great review
AI
Have had a SP8 for around 10 years and for the price it's really hard to beat. It's done all I've ever asked of it and bounces back for more.
Got that comparison done yet??? ;)
I for one, would be very interested to see it as I've bought two Ontario choppers, (the marine raider and kukri) and would be interested to see how this one stacks up. :)
JT
