- Jan 7, 2003
Green Coconuts
Opening a green coconut demands three tasks from a survival knife, cutting across the grain of the fibrous husk, piercing the hard inner shell, and splitting the nut in half. I have found the best way is to shave off slices from the top of the outer husk until the center core begins to be exposed. I keep a wide mouth cup, like a canteen cup, handy while I pound, drill, or carve through the inner core to catch the liquid inside. How you split the nut in half varies according to the tools you have.
Street vendors in South America often hold the nut in their left hand and deftly chop off the top with a machete. They then use a special coring tool to open a hole in the top. Add a straw and you’re sipping on a green coconut.
In a survival situation hacking at a coconut is not recommended. They tend to roll around. Often the liquid inside is under pressure and squirts out with great force. You can easily loose half the liquid content from a rolling, squirting coconut. More controlled methods are best both for safety as well as hydration.
Today I picked up five green coconuts at the market, for a total cost $2 USD. I decided to test five common survival knives against them. The knives selected were a Frosts Mora SWAK, Cold Steel Mini-Bushman, Air Force Survival knife, Becker BK-7, and a 12 inch Ontario Machete.
Frosts Mora Swedish Army Knife, SWAK
The SWAK did surprisingly well. Before starting to open the coconut I shaved off a slice of the outer husk to use as a spoon for eating the meat. The SWAK, razor sharp from the factory, sliced the spoon off in one easy sweep of the blade.
I then shaved off several half-inch thick slices from the top of the nut. Once the inner water-filled portion of the nut was in easy reach I used the point to carve a cone shaped hole out of the top. The short blade was very easy to control. This operation opened up a one-inch hole allowing the water to be drained into a canteen cup. It filled the cup to about ¾ full, 400 ml.
Placing the knife blade into the hole I then cut around the nut from the inside forcing the blade straight down and around the circumference splitting the nut into two even halves.
My three kids then devoured the meat and drank the water.
I found the SWAK very easy to use to open coconuts. The thin, sharp blade required very little force. The procedure was very safe and allowed complete use of the nut. I was surprised how efficiently the SWAK opened the nut. I had expected to work harder at it.
The Cold Steel Mini-Bushman handles coconuts very well. The blade is very sharp and is also thin, which greatly reduces the force necessary to shave slabs of husk off the top of the nut. I had to pound the point downwards through the nut to open a drain hole, as this nut was also very hard inside. To save my hand I placed the top slice of husk on top of the handle and pounded down on this with my palm. It worked very well; three smacks and I had a neat triangle hole in the nut.
To spilt the nut in half for eating I used the technique of turning the nut onto it’s flat top and pounding the knife through from the bottom. I had to repeat this operation several times but got the nut in half very quickly. Using a large slice of husk to pad the knife you can do this all day with no damage to knife or hand.
One note. The handle on my Mini-Bushman is wrapped in rubber tape then wrapped in 550-parachute cord. The wrapped handle is much safer for hard cutting tasks than the slick metal on an unmodified knife.
Ontario Air Force Survival knife
The Air Force Survival Knife was a mixed bag. The blade is very thick with blunt geometry. I found it more difficult to shave off slabs of husk but by no means impossible. My AFSK is very sharp and the edge geometry has been lowered on my Lansky sharpener. Even modified like this it was the most difficult of the bunch as far as cutting was concerned. It was an exercise in the patient application of brute force.
Opening the drain hole was another story. The AFSK has a very strong point and a hammerhead as a pommel. Pounding the knife down after padding the handle with a slice of coconut husk was extremely easy. Likewise splitting the nut was very easy putting that thick blade to use as a pry bar
Becker BK-7
The seven-inch combat utility knife was able to easily slice one-inch thick slices off the top of the nut exposing the inner core quickly. This was a tougher nut to crack with a much harder inner core. It was necessary to hammer down on the point to break through. This nut held 450 ml of water.
I started to use the “blade inside the nut” technique to open the coconut. This proved unwieldy. Laying the nut on its side I forced the blade down under my body weight against the outside neatly cleaving it in half. The wide spine of the Becker allows you to place your hand against it to add force to the cut. The BK-7 was very effective at the task when used properly.
12 Inch Ontario Machete
The 12-inch Ontario machete was reserved for the largest nut we had. No real surprises here. Rather than chopping at it I used the same method of slicing off the top. The machete was very sharp and the center core was exposed with three easy, cuts. Since the machete lacks an efficient point I used the curved portion of the blade to gently chop the drain hole. The first chop resulted in a face full of water. Rotating the nut several times making several more chops opened a nice drain. This nut held a half-liter of water.
Since the coconut now had a wide flat surface I laid it upside down on the end of a log and chopped it in half with one chop from the machete. By far this is the easiest way to spilt a coconut!
Since not everyone lives in a tropical paradise I thought you might like to hear how these common knives stand up to a valuable survival resource. Mac
Becker BK-7
