Manufacturer: Opinel. Savoie, France
Model: No. 112 Paring Knife
Blade Material: Sandvik 12C27-Mod
Design: Fixed blade
Blade Length: 3-3/4" (95mm)
Blade Width: 5/8" (16mm)
Blade Thickness: 0.039" (1mm)
Handle Length: 3-3/4" (95mm)
Handle Thickness: 3/8" (9.5mm)
Tip Design: Spear Point
Grind: Full Flat with taper at tip
Handle Material: Beech wood
Tang Length: 2/3 length
Weight: 7/8 oz. (25g)
Price: $10, including shipping
Summary: It's a slicing demon. Get one. If you prepare food, you'll appreciate it. I don't recommend this anymore
Performance - The purpose of this knife is to cut up food. In that, it excels. The thin blade glides through fruit and vegetables. When I use it to make dinner, I can't say I miss my full-size kitchen knives, unless I'm cutting up something large, like a melon. It is a smooth, efficient cutter.
Blade Geometry and Steel - Gotta love a simple, full flat grind (with secondary bevel, of course). At the last inch of the tip, the blade tapers so that it flexes like a fillet knife. The point is so fine that it is impossible to avoid damaging it. The spear point makes for effective draw cuts on a cutting board. I really like the Sandvik 12C27-Mod. I'm a person who values ease of sharpening over edge retention. I touch up the edge before I use a knife. With a few swipes on ceramic rods, this knife is shaving sharp. NOT! After 9 months of use, it needs a bit of work to get razor sharp, and doesn't hold its edge for long.
Ergonomics - The one gripe I have with this knife is the small handle. It doesn't fill the hand, which is not a problem most of the time. I cut up and skinned a butternut squash with this paring knife, and the base of my index finger got a blister. For everyday cutting of fruit and vegetables, the handle is perfectly adequate. The wooden handle is not slippery at all. The tang is a bit sunken into the handle, but it does not cause discomfort. A strange but rare occurrence, due to the symmetrical spear point, is I once held the knife with the blade UP. Now, I look for the exposed tang before I cut.
Construction - The blade is solidly fastened to the handle with two rivets. The tang is 2/3 the length of the handle, which is perfectly adequate for light cutting chores and kitchen work. While an excellent paring knife, I would not use this for a bushcraft knife.
In conclusion, this is a very useful kitchen knife. Its look and feel are quite similar to the familiar folding Opinels. There's a lot to appreciate about a simple knife that just flat-out works. For $10, it's a no-brainer if you need a paring knife or are the slightest bit curious. After long term use, the lack of edge retention is a deal breaker for me. This is coming from a guy with only knives less than $40, so I'm not really picky.
