- Sep 20, 2015
Pinnah wrote :
When I click on the link it just says couldn't find the info.
I have a brand new Opinel #12 (yuuuuup the big one).
I want to have fun fooling around with the pivot.
So far I have let very thin machine oil soak into the end grain of the handle at the pivot. I just rub a good pool of oil on the end and let it sit upright under a lamp to keep it warm until it soaks in then add another application. I have done this maybe eight times.
I shy away from submerging it I don't want to clean out the slot and waste all that oil to boot.
From here I am thinking of adding some applications of Tung Oil to the end grain.
Mostly I want to hear about tuning the tension of the inner collar etc.
I sharpened it and have used it some. Mostly it will be carried around the house and used predominately in the kitchen. I'm not too concerned about food safety of the Tung Oil I won't use much Tung Oil, it will cure and become no big deal.
I make fun of Opinels for the tight joint syndrome . . . yet here I am, once again, enjoying fooling around with another one.
Regarding tuning the joint to control the tightness, I think you got a hold of bad information. The hair dryer trick (or hot sunny dashboard) will dry out the wood which cause huge swings in the tightness. IME, its much better to soak the joint in mineral oil or vaseline to stablize the tension and then set the tension by adjusting the inner collar. I describe this here:
https://dl.dropbox.com/u/28597626/tuning-opinels.txt
