Plus harder to badly hurt yourself .Plus no gas/oil/chaps/helmet/noise
$159 over there at the moment for the 500. Tempting...Ah - fair enough.
I waited for years before buying a Katana Boy but when I saw it for $200 shipped from Jeff Bezoar I grabbed it. Has gone through some pretty big downed trees. Not chainsaw fast but certainly chainsaw capable if you have some time. Plus no gas/oil/chaps/helmet/noise.
I should've specified the use, my apologies. I plan to put the saw into a backpack to go venturing into the wilderness with (backpacking)I have only one . A Hayate telescoping pole saw .
Expensive but well made in Japan . Worth it for my use .
Best ? That all depends on what you need and how you use it .
As others have said above , these are thin blades and used only to pull cut .
You have to learn to use them properly , for best results and to avoid damage to the tool .
Will they beat a chainsaw ? Nope !
But for a lightweight , human powered saw , they cut with impressive ease and speed .
It's still a Silky saw and the general principles of how they work are all similar , or so I expect .I should've specified the use, my apologies. I plan to put the saw into a backpack to go venturing into the wilderness with (backpacking)
Mine folds up and is roughly 16" in size when folded up, isn't that back pack size? Or should I opt for something smaller?It's still a Silky saw and the general principles of how they work are all similar , or so I expect .
Putting a Silky blade on the end of a 21' pole only exacerbates any problems , like having the blade get caught due to binding in the cut .
A backpacking sized Silky would be much easier to use .
Just depends on what you need to cut vs. how much you are willing to carry .Mine folds up and is roughly 16" in size when folded up, isn't that back pack size? Or should I opt for something smaller?
Well my concern was to not buy a saw too small that would impede whatever branch/tree I intended to cut, but not too big either that it would burden me to carry it around. I got it on sale, so I think that was the reason I purchased it when I did.Just depends on what you need to cut vs. how much you are willing to carry .
That has a LOT of rust, no kidding on the miles aspect!Here is one of mine that has a lot of miles. The tip snapped off from me being tired and slacking on technique.
Still cuts great.
Nothing to direct you to that has all that info, but I just grabbed my calipers and a few Silkys (couldn’t find my son’s Pocket Boy) and here’s what I found:Pull-Saw Question:
With the performance and popularity of Silky Saws (pull saws in general), is there a place where non-professionals (non-arborists forums) discuss & detail these saws are discussed in detail?
I have many times past, and again today searched the forums here to find little discussion (considering the performance value of this tool).
The reason I mention "non-professionals" is because I generally believe pros, arborists, carpenters, tradesmen in general, etc. would be more apt to focus on fixed saws. pole-saws, etc. vs folding versions much the same way my 30-40 year old carpentry pull saws are of fixed designs and or two-piece w/ removable handles.
One example of the type of info I have had hard time locating is accurate comparisons of blade thickness and kerf thickness of all blades from a single source comparison (spine aka back vs teeth aka front and from heel to toe). I have only seen one comparison document and the values do not match measured values.
Appreciate any leads.
thanks,
