Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
Steel that has been rolled develops a grain direction. Kinda like wood, though not really. Perhaps more like a sheet of paper, which is easier to tear lengthwise than width.
I came across this years ago as a hack machinist when I repaired a lever operated valve with a piece of steel and made the shaft across the grain. Broke within the day. The replacement, made with the grain, was still in production years later. Grain direction probably had a lot to do with this.
So anyway, I'm wondering what is the best way to orient the grain in a blade? I have always run the grain in the direction of the blade. If I imagine that blade in wood, with the grain running it's length, the blade and tip would be strong, but the edge would be easy to fold and break.
So what I'm wondering is, in a hard small blade not subject to rough use, but instead taken to a fine thin edge, would it be better to run the grain across the blade so it is perpendicular to the edge?
Does this question make any sense?
I know the heat treat probably makes this question moot in most steels because the martensite grains form after HT, so the question is really more about high carbide steels.
So, what effect does direction play in a non isotropic steel?
