David Martin
Moderator
- Apr 7, 2008
And this one was up there. Sure it cost more and it has the reburn tubes. Which is the only item I've replaced in 16 yrs..
I don't know why someone has to get up several times a night to tend to the stove.
I had a Fisher and Lopi before, in other houses that were bottom draft with no tubes or plates.
They were bigger, uglier and less efficient but you could burn any wet or green wood in them and keep it going hot once you got some good heat started.
Definitely! I learned that the hard way and the first time I cleaned my chimney I was discouraged. But then I learned my lesson and bought some bone dry maple from a buddy. Ever since then I've only burned very seasoned hardwood and though I do clean my chimney twice a year it's almost perfectly clean when I do.It really matters that you're burning good dry wood with the more efficient stoves, they smoke and smolder and clog up without producing much heat otherwise.
