David,around here people burn wood that was harvested dry,dead-standing,immediately.
As opposite of that the green,even Very green birch taken in the spring and totally filled with sap,could be used that same fall provided it's been split at least in halves.
Air movement is the main ingredient to drying,more than temperature(T helps as warmer air can absorb more moisture,but once containing moisture it still needs to be moved away,exchanged).
It's possible that your best drying conditions would be a rick outside,in as open location as it gets,covered with some sheet iron...(that old heavy gauge galvanised corrugated roofing is great stuff).That is vs something clingy like a tarp...Driven moisture from the sides doesn't seem to do harm,it just evaporates again,meanwhile the air circulation is unimpeded.
In an ideal situation one could do like in some regions in Germany,where an extra room is built onto the house around the back entrance(i think...).It's ample enough to have all,or most of winter's wood stacked in it,but also the stove faces into it,through the adjoining wall.That way all ash removal doesn't happen inside the home,but more importantly the stove uses exterior(but pre-heated)air,not using up the inside oxygen,and creating positive pressure inside the house(doesn't suck in drafts like negatively-charged house).
I used to dream of stuff like that when i was young...But now i know better,and am reconciled to the more ...mundane...pedestrian...(maybe even slightly tending to primitive...)
Tonight
Patchy ice fog after 9pm. Mostly clear, with a low around -46. Wind chill values as low as -65. North wind around 5 mph.
Sunday
Patchy ice fog before 3pm. Sunny, with a high near -33. Wind chill values as low as -65. North wind 5 to 10 mph.
Sunday Night
Patchy ice fog after midnight. Mostly clear, with a low around -44. Wind chill values as low as -65. North wind 5 to 10 mph.
Monday
Patchy ice fog before noon. Mostly sunny, with a high near -31. Wind chill values as low as -70. North wind around 10 mph.
