Seedy Lot hives basic good advice but it requires some well controlled parameters.
The peak hardness depends on more than just the temperature of the oven. It also is controlled by the structure before HT and the quenchant and quench method. It also requires a calibrated and accurate hardness tester to do the comparison tests.
What many makers do is run a test HT on a batch of seven identical stock reduction blades ground from the same batch of steel. 4" is enough blade length and a 4" tang gives enough grip.
Quench in the same quenchant at the same temperature. Start 15° below your target and raise the oven temperature in 5° steps up to 15° above it (allow the oven a 10-minute stabilization at each new temperature).
They don't need to be fully functional or "knife-shaped" knives - just grind a bevel and put an edge on a bar of steel. Temper all in one batch together at 400°F.
Put duct tape on the tangs for a handle. Now you can finish the bevels as closely identical as possible (120 grit is fine), sharpen them the same, and test in many ways to see how the edges hold up.
Do cutting tests on manila rope, cardboard, wood, and do an edge flex test (brass rod test). If you have access to a hardness tester, grind the tangs flat and parallel and have them Rockwell tested.
TIP -
When doing multiple test blades, use stamps to stamp each tang on both sides with a letter or number. Stamp deep so it will be there after clean-up. Make a log with the numbers, HT parameters, etc. for each blade.
This is also a good idea on anyone doing multiple blade batches or using several types of steel. Sharpies and paint pens will rub or grind off too easily ... if you even remember to mark the blades. Stamping stays on the tang pretty much forever and can be quickly re-stamped if needed after heavy reduction.
It is always a good idea to stamp the tangs on your blades. Harbor Freight has a letter/number set for $15. Stamping the tang on every blade and keeping a logbook can make identification easy during construction or later on when doing a repair. Consider it the Westen equivalent of a Japanese mei. A good system is to use a letter for the year and numbers for the blade number that year. If you started in 2010 with A, a blade marked G-31 was the thirty-first bade make in 2016. Look it up in you book and you know the day you made it, steel type, HT info, handle material, and maybe the original purchaser or other notes. While making a spread sheet is the modern way, a physical logbook is more impressive and less likely to be lost because of a computer crash. The more info you put in your logbook the more you become consistent in knifemaking.
