Oveready, McGizmo, Malkoff, 47s, Nitecore Flashlights
TyTEK
Platinum Member
Feedback: +58 / =0 / -0
Doing some spring cleaning today and decided to post these items I don’t use. I'll post pictures of everything in follow on posts.
PayPal G&S only, no trades please. I ship within the USA via USPS priority with tracking.
First to Post or PM a claim gets it. If it’s not marked SPF or Sold, then it’s still available.
No batteries included.
1) Malkoff MDC body (1x123) with a VME head and Illumination Supply M361 Nichia 219B V2 light engine (3.4V to 6V input).
This one has been carried a few times, no scratches, or dents. Very little actual use. Beautiful tint, I believe the LED specs are very similar to the V3 drop-in: 4000K, 95 CRI, with three modes: 10 lumen / 70 lumen / 330 lumen
$old to your door
2) Oveready BOSS Frosted Titanium 35 and 70 Combo
Head is v5 with XPL High at 4000K with Amber secondary. This set is basically brand new. I’ve never carried it or really used it besides taking out of the flashlight drawer and fondling it every once in a while. It’s way too nice for me to carry around and beat it up. Really looking to sell as a set. I've swapped the button on the 35 body, but the original will be included.
Withdrawn
3) McGizmo Mule with 1x123 Body and HIVE with XP-G2
The head and body are brand new, I just received these from Don. The light engine came out of a like new Haiku that I sent off for a Tana mod, so it’s practically new. Really beautiful, rosy 4500K XP-G2 that Don uses. 4 light levels, not sure on the exact output. I’ve dropped a little solder on the connection to allow programming of the light engine.
$old
4) FourSevens Titanium Mini ML with XP-G2 led.
This guy is brand new, just been sitting in the box for quite a few years. I took it out of the box to test it and check the battery (battery was about done, so none included).
$old
5) Nitecore TM15 Neutral White
This guy is basically brand new as well. It’s been taken out of the box to test, but it’s just sat in my flashlight drawer for years. I’ve got a TM26 that I use all the time, so this one never gets any love. XM-L U2 emitters, not sure what the color temperature is, but it’s definitely on the warmer side compared to my TM26.
$120 to your door
6) Malkoff MD1 modification with an Oveready DPC clicky tailcap, custom heatsink and retaining ring, and TorchLAB v5 Triple P60 drop in.
See images below. The body was cut down from a larger Malkoff tube and re-threaded by Martin White on CPF. He also made the custom ring and heat sink shroud for the v5 drop in. These parts have only been assembled by me and power tested, but never used or carried.
Notes: The drop in specs are XP-L Hi 4200K primaries with a Red (640nm) secondary. Drop in is rated for 32W and 3500 lumen. This thing is a little bit chunkier than an Oveready B.O.S.S. and functions just like one too, optical programming and all.
With the Malkoff head and custom heat sink, I've been able to run this exact setup on the highest levels for quite a bit longer than a B.O.S.S. flashlight at similar settings before thermal regulation kicks in, just because of the additional aluminum mass. Plus, if you've already got other Malkoff bodies, the drop in can be used with them as well.
This body will accept 18350 batteries. You will need a high current drain IMR battery to run the v5 drop in at higher brightness levels. I have been using the Keeppower IMR18350 1200mAh High Discharge Flat Top with this exact engine with good success. I believe Efest and Vapcell offer similar cells that will work. They all run about $5 to $6 a pop.
withdrawn
1) Malkoff MDC body with a VME head
yjNIyu7DIUjs9aHZkXYHhYZn6EnZ1uZ2bDUSvn_2Bxxm6sUM9i43ttBgwiSEvICILVUKrDKZ2UvpUOcNV6TvJuNz_mTCmgl_gtnh7siHGyChxGmc-PxssTqFRlYSxghwcVwBGjtZBQ=w2400
oWWVlKBwonD4-uz_INFVlyWWMhzh8MkfbkEXfF8wnM7YrApMxQ9lH-etlgJVfwf8dj5fGv-zeuYOAmsdc4207IfxzmkizcD2Msj8fIEjgpAa0HKba3ETOR_oKPvkMOfpeirXIi2AHA=w2400
uECxqN2-qbI6FqbIn9gWSVAI6ymTIHOQiIWAu_crxObvgz8dWsPlI7GAKU1Q8A6L8rpAq4EPT1CAT49yZ9iYteAcvl1BKiz4McQ6MT6-_67nF1oGPm6ojRqap3PBXLMdRB2R7znO-g=w2400
Note:
I didn't bother pulling the tape off of the leads on the light engine (they're probably not necessary in the mule head, ha), but it's a simple thing to do if you want to change the aesthetic a bit. Would probably look better.
20EZDSFnM2Pbxe3nIWu_jClBDTXUsrLFeTS1SED4PmBbCb80_1GckpNEw_D6DOJt2mJ0qbOxo16PVYlYqOw9VzSsSUvIL27lYYmt48RdyNq7eDXq7hDAJHtk661FyPG1Ke5RL8YvcA=w2400
e6c523dc3SxubB6ZxNyBgr7oOf8BGq3BaNiJ2rS-o2B4CWshVTh7fdmuYIhVHNPq9SFeCZ5rT-uFTB0ax3hOjBdxu43cY7MoKe2U7PZ56OQeamNKp4fMln2jzvi-IFxj5G_G5eJwRA=w2400
4VtaZ-cBYyGbY0ATof5ufuoYUQJElRqpqOza7K43kbcmkyfjbIQ8OXExb6LU39HLnStJhkWwZw2AITS1xGrSIwkuIFdHw3mDtW2JyJUc5l-9oPk7CVFArTZ0EREU55b_rcvIcxkeig=w2400
tKC1P-uQDwr1wsobkyBmeP7v3yUJrbGxR9WY2YwbQOa15Y9ofKMy84oRMUMAcXNYMd58nJ8_uOQGaEzWh9N_IZeOPHBxnvX2WjOPRFtWo9gZMlY7iMq144y6tBQToycvaQ91tgGKTA=w2400
g3zdWGo2lldn7DPmNBQEHh4YWSnf5p2_UgZRyTVsgsA-9Z1B_mpkgoO415vygjTUswW8CigGLwLWeAa-4AvLmoxPZGQZk3W0z7zhj398MoW_qOdXk4gs0klgR3SZQp7Fe66iw21hCA=w2400
KlnQQp8bN1JJkZljjQ1lLFhjG59Lff77XpCHAOm3Ye5VhK_oouU9B7CwclRPaZh4rAXllbN_RdAd_75D8wDUK0MG8glRT-qmSO6OTb1Rgpwat1UPb2wnMLcCVP7-2OHLTjf01FSI0Q=w2400
N6FLPS0fSkCl1U6d5F5VavZ7CSw9xaf1ozrQer4_oCGeo50wjuR8BdKKZAw2gZk0FFQLbav56qdLSMg02G2s8gESBqB4b05WvYpvLZZZOos0hWXup62N1sZUH2pq_pRUDiy3t4Awfw=w2400
KTGW4XoVzzf5l7ZyYGvVn_wqvvfWimm2FOrQG_ybVMUS1b-ldkZoSm-us5DpOz59oYVjhsIRKr308JOi9e8aV7bpqtd8Go16_Cm9aLsTLH-o2_1AYOn1_9O9D_EXUj2iYLx1cqp1wA=w2400
XPr1NWugOH60CuJ7v-7j7HV2pYdpeZ6ejOJtH2gqpnzT0IYFi0pNZBHRhvsoOlR5DVkb9mfiekpN-oBujXW1qC5ebP5F26gTzQ5klLAfA2yUE95iy2Vrhfb-bizbL60R0usXk-LOBA=w2400
lYnKBa1A2NpTbuDyIXsHNvsEJcO95vf2f7HyIm_Rtc7ju-E-eo4FjmCkmgnlj54qC6BQJONrzYefSD3Kpo7u-X2FOsT3ZjXM_Yk5ytzWP23hjvui5omD2-UNL1pe_8GD_CfXMgWWlQ=w2400
I would love to buy the MDC with Oveready tailswitch or the 35/70 BOSS combo if still available! Or both!👍🏻👊🏻
