I can promise you that Powernoodle knows something about knives. Maybe you haven't been around long enough yet.
The majority of people buy knives to cut, we are not in the majority, but we can relate to their opinion of how a knife is a tool used to cut and a $60 FFG spyderco will do basically the same job as a $1000 custom
He doesn't know anything about large fixed blades... And if he wants a small item to just cut stuff efficiently on a budget, he doesn't even need $60...
If you want a small tasks high performance cutter for a low budget, nothing will beat a boxcutter and a stack of spare breakaway blades...: That's all that gets used on actual construction sites, and for good reasons, as they stay sharp, and so are much safer than some tiny folder that will get dull... So even $60 for a small folder is a rotten deal in that context...
As far as large fixed blades go, maybe a $200 Esee Junglas will perform well (though I kind of doubt it when I see it beaten by a Trailmaster, of all things...), but an Ontario SP-52 will probably out-perform it by a lot for a lot less... And I still would never recommend an SP-52 if you want long-term use, because of the likely edge thickness...
The trouble with all cheap big fixed blades is that they are
all thick-edged: Even my San Mai III Trailmaster was thick-edged because of its stupid convex edge... Thick edges mean that, after use and resharpening, the knife gets duller and duller, and after a few months of resharpening the angle becomes so open the thing is an accident waiting to happen (I have had a trip in an ambulance to remind me of this)...: The Bk-9 was a little thinner than most, but it was still too thick-edged to really last the distance...
The best bargain in large chopping fixed blades I found is the Randall Model 12 with a 14 grind: It performs the same after dozens of resharpenings because the edge geometry is a thin 0.020", and, crucially,
this thinness has a built-in reserve of wear, meaning you can go upwards on the edge and it doesn't thicken: Because of that, and the incredible quality of Randall's forged 440B steel, which seems literally unkillable even at very closed edge angles (even beating INFI in wear-resistance by a wide margin while chopping concrete), the knife wears and stays the same thinness, while all the other knives become open angled and thus dangerous junk...
Furthermore, the Model 12 out-chops the Bk-9, the Chris Reeves Jereboam and the San Mai III Trailmaster by almost two to one... The almost equally thin-edged Lile "Mission" does do about 25% better while being 3 ounces lighter than the Model 12, showing that going even much higher in price sometimes still yields some noticeable dividends in performance (if not finesse of finish in this case: Yuck)... The opposite of what is usually spouted on this...
I have simply trashed my Trailmaster and the Bk-9 (poorly made with a commonly heat-curved blade), and I still have my $950 Model 12: Around $450 in the trash and I still have the Model 12: Which is the greater user bargain?
Gaston
