- Aug 20, 2018
I was lucky enough to acquire a portable oxy acetylene rig from my uncle after doing some work for him and I’m hoping to get it up and running so that I have a convenient way of heat treating my knives. It came with an MC acetylene tank (empty and of questionable integrity; probably going to replace it), a B oxygen tank, a welding torch + tip, and a cutting torch + tip.
I’ve been looking for a place to supply the gas and it’s been a shitshow. I’ve heard only bad things about Airgas and their prices are ridiculous. I don’t think I’ll need anything larger than an MC acetylene tank and B oxygen tank, but I’m not sure as I have no reference for oxy/acet gas consumption. I’ll most likely be using the cutting torch for the heating (3/16” stock, 4”-5” blade length).
Would it be worth it to get this set up or is it a waste of time? Should I just go with a large (20k BTU) propane torch and cylinder? If it is worth it, should I go with Tractor Supply Co. as a gas supplier? Finally, are the previously mentioned tank sizes adequate?
Thanks!
Thanks!
