- Mar 28, 2009
In the process of testing one now (On loan) and from what I have experienced so far CTS 204P is VERY aggressive.
Any way you can test one alongside the Southard?
Any preliminary thoughts compared to BU M390???
All I will say is that I'd love to have a slot in the collectors club unfortunately, information on it has been difficult to come by.
Don't own one and they are pretty thick behind the edge.
From my testing so far 204P seems to be slightly better than M390 at 61 RC, edge retention on rope.
420 cuts to 380... or about 10% or so.... So they are very close.
Interesting - since Carpenter is technically on Gen 2 PM processes and BU is on Gen 3???
It won't make that much of a difference, and I don't know the hardness of 204P.
10% is VERY close in this type of testing.
Even more, most likely it safe to say that at least 10% is uncertainty of measurement.It really is.
This sort of testing has a lot of variables in play, some you can control and some you can't. Even if you control all the variables you can, and even if you have years of experience, 10% is extremely close due to the nature of the testing method.
They wouldn't be limited editions of everyone had them.
I'm not so sure that the average knife enthusiast cares if they are limited editions or not. I like that they are different from the stock model, but I don't care that they are rare. I think a lot of enthusiasts would like for them to be more available so they wouldn't be so concerned about actually using the ones that they own. Right now if you for instance have a green one and like to use it, if you break it or lose it you will have a hard time replacing it. Other brands make some models with interesting steels but they produce enough of them that it is easier to justify owning one of them as a user.
This! I have always said that the "specialness" of my (fill in sprint here) will not diminish with additional runs because my knife will still be made of the same materials and will be the same design that attracted me to it in the first place.
I'd even venture to say that the persons most concerned about the "exclusivity" are the spreculators.
Also two knives were tested and compared. This is not the same as two steels were tested. There are variation in chemistry from melt to melt, as well as variation in heat-treatment between heat-treatment lots of the blades and from blade to blade withing the same lot. It will not surprise me if somebody would test about 50 production paras S30V, which were produced within few years period of time, which blades associated with different material heat numbers (melts) and of cause were heat-treat in different lots, the results will vary more that 10% within the same steel.
I remember before this knife went up for pre-order there were many who disliked the color choice.I bet you some of the folks wished they had chosen to pre-order.Green is my favorite color and that won't change.I much prefer forest green over smurf blue or anger orange.I wold like to see another 400 produced as I read some where this steel might/has been discontinued by Carpenter.Please advise?
