- Aug 25, 2002
Yesterday I forge welded a little billet of alertnating layers of banding strap(1095 ?) and Industial band steel cutting band saw blade( l-6?) This was 70 layers. I drew it out to doubled length, hot cut in half, Made a final weld with thicker bandsaw steel between the two 70 layer laminations. All welded great billets is 3/8. I got the billet up to non magnetic, and put it in the hot box(vermiculite). This was to facilitated the offset grooves for the ladder pattern which was supposed to go as deep as the center piece of band saw steel. Now the problem is here: The weld was so good I couldent see the center so a ground an polished then etched...Pretty....But I expected the center stuff to be shinny silver not dull grey to black. So what happened. Did it etch oddly cause its not heat treated, or does l-6 etched turn black, I thought the cromium content steels stayed silver. And the 1095 being softer turned black. Ive used this material before for pool and eye and twist and modified ladder. And whatever pattern I got I was happy with.....Any ideas guys....thanks, Bob
