It's a great alloy for a hard use type knife. It's very tough, has decent wear resistance, but isn't as corrosion resistant as CPM 154 or S30V. That's why Strider coats it I suppose but I can use that class of steels without any coating. It is more corrosion resistant than 1095, O-1, etc.
IMO, and depending on the heat treat and final hardness it is probably a bit more wear resistant than 3V, but slightly less tough than 3V. In other words it's excellent for true hard use. The balance between toughness and wear resistance is, IMO, one of the best. CPM Cruwear, Z wear, and a few other less well known names like Lescowear are pretty much the same composition.
The Original, Vascowear from Vasco Pacific ( *note: may have existed before but this is first company I found carrying this particular alloy) was used first in production by Gerber as "V" steel in the 80's. Vasco Pacific and Vascowear are both gone but the ingot Cruwear, as well as newer powder steel CPM Cruwear, PD#1, Z wear, etc. have brought this alloy into this century by mainly making this steel which was notoriously difficult to work much easier to work by the powder steel process which also gives smaller grain structure and even better toughness.
Wear resistance as it applies to our hobby should be between D2, and CPM M4 ( closer to the M4 side usually though the heat treat has a lot to say over this attribute) and toughness well above the D2 level and close to the Shock steel levels.
Cruwear does just fine at RC 62 and doesn't lose toughness at higher hardness rc62-63 as much as 3V does. 3V, while starting out higher at rc 58, loses it faster when getting above rc 61 and isn't a good choice for a high hardness knife, or one that will have a treatment applied using high temps.
