- Jul 26, 2008
So basically with all of the knives I make I use steel or brass pins that that are peened in place. Epoxy is only there to keep moisture out. The problem I am having is that no matter what I try whether it be a hard backed sanding block, or a perfectly flat file, or whatever, you can always feel a slight bump when you run your finger down the handle over the pin on a finished knife. So is this just normal and unavoidable with peened pins? I made a different knife where the pins were not peened, only epoxied in place and they seemed to sand out a lot more flush, can barely feel them if at all. I prefer to peen my pins because I make historical type knives.
Also tapered the tangs on these 18th century style scalpers...all in the name of historical accuracy.
