- Aug 27, 2008
Im getting a Bm 42 and was wondering if the permatex loctite is good? or should i get a different brand?
thanks
thanks
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Both Permatex and Versachem make a good product. Look for the "Medium" strength, and DON'T TRUST THE PACKAGE COLORING. I don't know why, but it ALL comes in a blue plastic container these days. It really confuses confuses things...
thanks
Greetings: Has anyone tried this stuff? {Vibra-tite VC-3} It claims to have addressed one of the annoyances I encountered using Blue Locktite on adjustable tension pivot screws. The maker claims that this "Liquid Thread Locker" permits screw adjustment after it sets up.
--" Using steady pressure and standard hand tools, parts coated with Vibra-tite VC-3 Original can easily be adjusted, removed, and reused". --- http://www.ndindustries.com/vc-3.php When using Permatex or Locktite, I usually adjust the pivot screw tighter than optimum, knowing that the action will loosen a bit with time and use. After a while the pivot requires readjusting. This breaks the locktite seal and some screws start backing out. Rather than risk loosing a pivot screw, I wind up re-cleaning the threads and reapplying the liquid threadlocker. This stuff, if it works, would eliminate the need for initial over tightening, the thread cleaning and the reapplication of fresh LockTite. Anyone have experience with this stuff. If it was available locally, I would have tried it already. OldDude1
cyanoacrylate is known, standardized technology. One brand is as good as another.
