- Sep 17, 2013
I have a quick write up on a knife from Mr. Wilson. I received this model a little while ago and have been using it daily to see how it performs. The steel is Vanadis 10 @64/65 HRC and is a 3rd generation HCV powder steel. It is similar to A11 grade with added Chromium,Carbon and Molybdenum. I haven't used the knife in wet environments yet but may have added corrosion resistance over A11. The edge holding is very high from what I have experienced so far. Sharpening this steel on SIC stone worked fine but I found that a 600x diamond plate got the more crisp edge. Using the proper sharpening equipment is important to cut and shape the carbides to get a scary sharp edge on this stuff. I'll add more info to this down the road.
Blade length on this is 3.75" from tip to scale,
Stock .135",
Handle is Black linen micarta, red G-10 spacer, brass pins and stainless tube
Flat grind with distal taper,
.011" behind cutting edge
3.5 oz
image by waterstoneblades, on Flickr
Stock .135",
3.5 oz
