Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Hi folks, I recently tried my hand at transferring a photo onto a wood plank that I routed two grooves in that I put on top of an open drawer on my desk, making a small side portion of the desk. I glued two sections up to get the size I needed and sanded it down smooth.
Then I took a sheet of printer label,
Remove ALL the labels so you just have the slick side
Print onto THAT side, the ink will not soak in as it is a waxy smooth surface
I lay a strip of tape sticky side up on the wood and lay the sheet of paper down onto that
Carefully FLIP the paper over and align it up, I let the middle of the paper bow down naturally and let it set itself down onto the wood
Press the tape down onto the wood, TAKING CARE not to move or shift the paper as that will smear the image
Then carefully smooth along the back of the paper...again do NOT let it slide/shift around and press down so the image is being put onto the wood.
Remove the paper carefully up and let it set to dry for a short while
Take a can of clear spray lacquer and spray a coat over the image to preserve it and prevent it from being smeared
and voila
Shiny !
an 8 x 10" photo onto my wood desk addition
Untitled by GaryWGraley, on Flickr
G2
and voila
Untitled by GaryWGraley, on FlickrG2
