This is a heavy duty (emphasis on heavy) grinder, all welded design with an extendable arm to handle belts from 72 to 100" for greater versitility.
I am running a 1 1/2 HP motor to a lay shaft which can handle several stacked pullys for variable speeds and a self tensioning belt. Changeovers will take seconds and no tools.
The wheels are mockups from wood but production models will be steel or aluminum with a rubber covered contact wheel, buyer's choice of diameter.
Additional tool arms will be made available for small wheel grinding and flat platen work once I get time to make up prototypes.
I am considering a tool rest as well for those that need one.
Pricing will be less than $800 for the base with out motor, motors can be added based on local availability.
George
