Hickory n steel
- Feb 11, 2016
I had a very minor problem with the new left handed sheath for my 119, I came up with a very easy fix and because it was so minor with such an easy solution I'm not complaining at all.
My problem with it is that the plastic is just folded in half, this crease which the spine doesn't fit into pushes the edge against the welt cutting into it and makes the fit a bit tight.
It turns out it just slides out however removing it leaves too much wiggle room for the blade so my solution was to cut the end off and inserted it backwards.
The edge actually fits into this crease in the plastic unlike the spine, this covers and protects the welt, and since the spine has more room it loosens up the fit perfectly.
I just figured I'd throw this out there, because I had assumed the liner was probably glued in or something.
I don't imagine this would be a common issue if it wasn't in reality just me , but luckily if it does occur as a problem it's an extremely fix.
I also needed a solution for the belt loop that just didn't carry how I prefer.
I added some ranger bands just above the Buck logo to tighten the loop up some, and run my belt behind what is supposed to be the loop.
Now it's perfect, and only took mere minutes.
Im not complaining, just happy that I could tweak this to suite me in no time at all.
