I am currently working on two hidden tang knives. Blades are finished and I am in the process of fitting the guard. Now I have read most I can find in books and on this forum regarding this topic but I just can't do it. I don't have a mill but that should not hinder me to make a good fit.
Here is what I've tried so far:
I drilled the holes for the tang undersize and marked my slot for the tang on the guard material slightly undersize. I drilled the holes and connected them with my files.
Then I used a carbide faced file guide during the rougher stock removal to establish straight lines.
Then I filed the slot on the side that does not meet the ricasso at an angle so that the area that has to be fit up is reduced (so basically the slot on the side of the guard that does not meet the ricasso is bigger). Then I took a file that had a safe edge ground to file the shoulders of the slot so it closer fit the tang.
I went really slow and took my time, checked often, rescribed my lines often, but I can't seem to do it...I am now at my fourth failed attempt where there are gaps in the final fit up (I'll post pictures as soon as I can).
I would be grateful for any advice.
Edit: also I am pretty sure my tang is flat. I flattened it on a granite surface with sandpaper....but who knows I spent the whole weekend in my shop trying to fit A guard...four times, at this moment I don't really trust myself much.
I was using Vallorbe needle files, so I was able to work with quality tools in my opinion.
