One thing I see regularly when newer makers are trying to fit a guard snug is that the tang is still the original bar stock surface and thickness. After the blade and ricasso have been ground and sanded, the area at the shoulders is thinner than the tang. You need to carry the rcasso sanding at least 1' up the tang, and the tang needs to be tapered slightly to within 1/2" of the shoulders. I like the end of the tang to be about half of the ricasso thickness.
A cheap digital micrometer from HF will allow you find any high spots that need more grinding on the tang, and to check that the ricasso is flat.
If the ricasso is tapered spine to edge, then make sure the tang is equally angled and that the guard has a matching slot.
When the tang is ready to fit the guard, it should be smaller in all dimensions than the ricasso past the first 1/2" .
These things will solve 99% of guard fitting issues.
When puting the angle on the slot from the back in filing/fitting, only file the angle half way down the slot sides. You then file the slot to fit more, and if needed, file the back side angle again. When the guard slot is finally done and fits snug, there should be nothing left of this angle beyond a small chamfer on the back side.
