- Apr 18, 2017
It sounds like the real thing. I don't think any of the other Nepal khukuri companies put kami marks on their blades, let alone one that would look like Kumar's mark. The lack of "U.B." and the kami mark on the right side suggest that it is an older blade. It was only after Uncle Bill passed away (in 2004 or 2005) that the "U.B." was added to HI blades in his memory.
Also, the wraparound leather straps is an older type of frog, most often seen on military issue khukuris, but also on some of the older HI blades.
Following is an example of something similar. It's a BAS model (15.5" OAL, 22 oz) by Kumar with his marking on the right side. Also, the "KM" is typical of Kumar's earlier blades. The sheath has a pair of leather straps, though not quite the same as yours, I think.
Please post a picture when you can. You have to use the "Upload a File" button in the lower right area of the Reply window.
Yes, that's it! The markings look identical to the BAS that your posted!
Thank you
