- Mar 19, 2018
Forgive me if this is too off the mark, but
FortyTwoBlades
are the trace diamonds in the American mutt enough to cut the carbides in m390?
I just finished my order as well... We'll both have to check back.Thank you all. I have one on order.
Forgive me if this is too off the mark, but FortyTwoBlades are the trace diamonds in the American mutt enough to cut the carbides in m390?
I would consider them present in high enough concentration to make a meaningful difference when sharpening steels with higher than 3% vanadium content. However, I can say that at ANSI 400 grit and below (which is the range of grits those stones are made from) you can effectively sharpen high-vanadium steel because the abrasive grains are large enough and the carbides are small enough (about 3µm) that they're simply scooped out with the rest of the steel during sharpening. It's mostly once you start getting into the finer grits that you start needing super-abrasives.
does anyone have a quick method of flattening this stone? Ive sharpening everything within a 1/4 radius and would like to flatten it out.
A word of caution with the American Mutt that to prevent glazing with it high pressure is a must.
Just the American Mutt specifically because it's a hard bond. The hardness of the bond will affect the requisite pressure for getting grit to shed in use to expose fresh cutting surface.Is this true just for the American Mutt or for all sharpening stones in general?
Thanks...
We're talking about putting a good amount of "oomph" into it. With the pocket one the small contact area helps but you'll definitely want to use more than stropping pressure, as that should be pretty light.
Sorry for highjacking the thread but I have a question regarding the American mutt. I love the stone but it seems I somehow glazed it. I thought I was using enough pressure but I guess I didn’t... It cuts really slow now and feels way too fine. I tried resurfacing it with a coarse silicon carbide stone and an Atoma 140. Both didn’t really work. What would you recommend?Just the American Mutt specifically because it's a hard bond. The hardness of the bond will affect the requisite pressure for getting grit to shed in use to expose fresh cutting surface.
For flattening I've had good success both with loose SIC (60 or 80 grit, I think) and with a coarse SIC "stone flattener" I got out of the big river that flows through the rainforest in Brazil, so not sure why that wouldn't have worked for you. If anything, the finish off the loose grit was really rough and was more aggressive than originally until it "wore in" a little. I will note that the Mutt seemed to lap the flattener almost as much as it was lapped, but it got the job done.I tried resurfacing it with a coarse silicon carbide stone and an Atoma 140. Both didn’t really work. What would you recommend?
What mesh was the silicon carbide?
