- Aug 29, 2010
That was quick fast and in a hurry!Dang you is busy, I call dibs and me stupid!
A real Fine Grind to the Spine! Nice, John.
Thanks Dennis, an added bonus of etching at completion over stamping prior to HT is I can give it a light surface grind after heat treat and bring that plunge right where I want it, them etch the ricasso.A real Fine Grind to the Spine! Nice, John.
Comes out nice and clean for sure.Thanks Dennis, an added bonus of etching at completion over stamping prior to HT is I can give it a light surface grind after heat treat and bring that plunge right where I want it, them etch the ricasso.
These will be getting coated with anti scale and all set for HT.
Those look sweet! I wish I could grind that nice.
I'll try to find the video but Neels Van den Berg has the best tip that helped me the most with my grinding bar none.Those look sweet! I wish I could grind that nice.
Control ALL forward pressure into the platen with your knee... bare with me.
With knife in hand and your arms locked tight to your body, try this stance.
If the handle is in your right hand, plant your right foot forward like your taking a step.
With the blade against the platen or wheel, whatever, apply grinding pressure forward by shifting weight to your knee and move it slightly forward. Be sure to your elbows and arms locked into your body.
This let's your upper body control and lock the position and angle of the blade, and your lower body control the pressure.
I can't find the video he did but honestly the moment I tried that technique I gained a ton of control.
If that didn't make sense, let me know and I'll try to describe it better.
A Serrano and a Corsair walk into a bar, 9 months later...
