Hi there!
Some time ago I realized that after selling my two old tactical knives I need to find some good military folder to my collection and for some hard tasks.
So here it is - the Pohl Force Mike Four Outdoor tactical military EDC folding knife.
The knife was designed by Dietmar Pohl - a talented and experienced German designer who formed his own company Pohl Force Knives in December 2008. In Dietmar's biography you can read that most of his designs are intended for police service and military use but hard outdoor and recreational use he also takes into account.
In 2012 the Pohl Force established close cooperation with the LionSteel company based in Italian "city of knives" Maniago to achieve the highest quality. In that way the Euro Ops Division brand was born and the Foxtrott has become the first EOD folder. The Mike Four is a successor of the Mike One (and Two) which was designed as easier to carry knife than the large Foxtrott. With its size the Mike Four is in the middle of the line of the Pohl Force knives thus it becomes very versatile and ergonomic.
Satin finished the 4 mm thick blade is made of a very good Niolox stainless steel and is suitable for the hard outdoor tasks like wood processing etc. The flat grind is perfectly symmetrical at both sides. The cutting edge is factory sharpened to a level of shaving hairs from hands. The modified tanto blade with an agressive but very interesting look has a length of 95 mm and opens up smoothly by a thumb disc. The lock is very strong and there isn't any blade play whatsoever. But if you'll ever need to adjust the pivot in the outdoors you can do it even with a coin. The knife overall length is 220 mm.
The handle is made of two pieces of 'hard coat' anodized aluminum and thanks to that the knife feels solid in your hand but very lightweight at the same time. A textured surface gives very good grip. The knife can be handled in two positions. I especially like the position with my thumb placed on the ramp and my index finger placed just before the cutting edge. This allows for precise blade control.
The Frame Lock locking system was improved and it has an additional steel insert which gives a safe and rock-solid lock. This steel insert thanks to its protruding part placed under the frame protects the Frame Lock additionaly against an excessive opening when you release the lock.
A hole is inside a pivot and together with a second redesigned hole at the end of the handle you can use them to interlace a cord for a hand security improvement during the hard work. In survival situation you can also use these two holes to firmly fasten the knife on a wooden stick and make some kind of a spear.
But it is not a joke. During my lonely outdoor adventures in the wild places like this below, I came across the brown bears and the pack of wolves three times already.
Stainless steel deep carry pocket clip with a black coating is at the end of the knife handle, what makes the Mike Four great for EDC - every day carry. The clip is reversible and screwed to the end of the handle by an integrated tungsten carbide glass breaker. A paracord lanyard with metal skull helps to deploy the knife from the pocket. The knife comes in a useful EOD black collectors pouch together with an EOD 3d patch and a certificate.
Pohl Force Mike Four Outdoor specifications:
☞ Overall length: 22.0 cm
☞ Handle length: 12.5 cm
☞ Handle Material: Aluminum
☞ Handle thickness: 1.4 cm
☞ Blade length: 9.5 cm
☞ Blade thickness: 4 mm
☞ Steel Blade: Niolox
☞ Weight: 140 g
Together with the Mike Four I also ordered some additional accessories including the Pohl Force Lima Patch and the Bravo/Mike Holster Gen2 which can be mounted on a belt and is compatible with the MOLLE system.
In summary I can definitely say that the Pohl Force Mike Four is very impressive. The knife is suitable for police service and military use indeed, it can be used in the outdoors, it fits well also as the EDC knife. The fit and finish are perfect. The blade is centered, the handle has very good grip, the lock is very strong, and the tactical look is complemented by many cool gadgets together with the very good and useful design.
Thank you Dietmar for your great work! :thumbup:
☞ Weight: 140 g
