The rash can begin within a few hours after contact, or it can start three to five days later.
Left untreated, the rash (a typical histamine response) will last three to five weeks.
A: There is no cure for the poison oak or poison ivy rash once it begins, only relief of the symptoms. Once the rash has started, washing with Oak-N-Ivy® Tecnu® Outdoor Skin Cleanser helps remove any free oils, thus allowing the skin's natural healing process to begin without possible recontamination.
itching... can be relieved with over-the-counter anti-itch treatments that contain zinc acetate (such as Calagel®), hydrocortisone (such as CortiCool®) or zinc oxide. In severe cases, a physician can prescribe antihistamine creams, tablets, or shots.
The blisters are the body's natural allergic reaction to poison oak and poison ivy plants. If the blisters break and ooze, the fluid does not contain the oil that causes spreading. Oil from the original contact with poison oak and poison ivy will continue spreading (unless removed) for the first 1 or 2 days. If new areas of rash appear after 3 days, you are getting re-exposed to the plant oil, most likely from contaminated clothing, tools, or even your cat or dog.
Mild cases of poison oak or poison ivy can last 5 to 12 days. More severe cases can last 30 days or longer.
Once the rash appears (i.e., within 1-3 days), the original oil has all bonded to the victim's skin, so it can't be spread to others.
Urushiol Oil does not evaporate and can remain active for a year or longer after being picked up on tools, clothing, animal fur, etc. Use Oak-N-Ivy Brand® Tecnu® Cleanser to remove urushiol from skin, clothing and tools.
Since animals' fur protects their skin from the poison oil, they typically don't develop a rash. However, the oil will remain on their fur and may contaminate you when you touch them.
Urushiol can be carried in the smoke from burning leaves or brush. If you think you have inhaled the oils, see your physician immediately; this can be a very serious condition.
Bleach may appear to be a quick fix to a poison oak or poison ivy rash. However, bleach removes the top layer(s) of your skin. Using it can irritate your skin and in the process weaken it so that the rash may become worse, or it could lead to an infection. Your skin may then become more sensitive to getting the rash in the future.
