Stacy E. Apelt - Bladesmith
ilmarinen - MODERATOR
Moderator
- Aug 20, 2004
All the polishing kits are gone, so this is not a promotional thread.
I have had several folks ask about the use of different polishes.
I decided to post this thread to give my thoughts, and encourage those who USE polishes to give their experience. Those who have read about polishes ,feel free to ask questions and post about things you heard/read, but let the guys who do it regularly post about what works and what doesn't. Lately we have had a lot of advise from folks doing their third knife, or so, as to how to do things. Sometimes that is fine, but for topics like buffing and polishing it takes years to get the proper experience to give good advise to others.
OK, rant over.
SAFETY - THE BUFFER IS DANGEROUS - IT WILL HURT YOU IF YOU DON'T RESPECT ALL THE RULES.
Buffers running too fast, having the wrong wheels, buffing with an edge up, not paying full attention, being in a hurry, and the most stupid of all - buffing from the back with the wheel turning up and away from you.....all will get you cut or worse. Buffer cuts are rarely a nick..they remove pieces of your hand in less than one second. Buffers can kill or severely injure you.
OK, now that we have chases all the kids and wives away.
The easiest way to get polishes straight in your head is to think of them by color. Black is the coarsest and white is the finest.
The rouges in the kits were:
Black - similar to fine emery. Good for taking out the final scratches and working up a matte lustre.
Yellow - medium abrasive good for getting a nice polish. Works good on brass/nickel,too.
Tan tripoli. There may be two colors. The darker is just a bit more aggressive than the lighter one. This is a polish that can get the blade ready for a final polishing.
White Diamond tripoli - For a high polish on blades, as well as buffing handles and ivory.
The rouges - red,green, yellow, white - are all for a final super bright polish. There is a slight difference between them, but they all do great.
Red is the classic rouge, and works very good on steel as well as softer metals like brass and nickel.
Green is best for stainless steel.
Yellow is wonderful for buffing and stropping the edges after sharpening. It also works great on most everything as a final polish.
The white is for ivory, and wooden handles. It will take any metal to a mirror polish, too.
The Linde A powder is for charging strops and polishing by hand.
Oil a leather strop and rub in some powder. It will strop the edge to a perfect smoothness.
For hand polishing things that you can't buff, moisten a soft cloth with baby oil ( smells better than WD-40) and work in some powder. Buff by hand. Keep the cloth in a zip-lock bag for re-use. To buff ivory by hand ( especially good for carved handles) use water to dampen the cloth.
You can also make a slurry of the powder and oil and use a small felt pad and a wooden stick to polish in sculpted areas, and plunge lines ,on a blade. Use the same method you used with sandpaper to get the area smooth in sanding.
Finally, the rouges as well as Linde A are also is good for doing final togi on Japanese blades. They work well for those who do a Hybrid polish. You can make some powder by scraping them on a spice/nutmeg grater. DON'T USE SANDPAPER - it may get grit in your rouge powder and cause untold heartache. A small 1" square felt pad and your fingertip works great for brightening/darkening along the hamon.
There are many colors and types of polish, with the actual abrasive being nearly the same in most, and the binder type varied. The color is almost always just an added dye. In buying polishes, do your homework and see how much the particle size varies. Some "Cheap" polish has a lot of larger grit allowed to get in with the finer polish...which is not a good thing. Many of the "fast" polishes are done this way to cut quickly. The finish under magnification is a lot of polished scratches, not a smooth surface.
Green polish can be one of two things. Green Chrome polish or Green rouge. Chrome polish is superb for stainless steel and it contains chromium oxide. Green rouge is a fine grit rouge made with iron oxide and dye. Some high quality green rouges have both Chrome and Iron in the mix. Green Buffing compound is usually aluminum oxide that is dyed to look like its more expensive ( and better) cousins. So if it is green, look for the words "Chrome" or "Rouge". A check on the MSDS or grit analysis is how to find out the content in polishes. Also, look at the percentage of binder/carrier to polish. Some cheap polish is mostly clay and wax.
OK, rant over.
